Differential fluid change - JeepForum.com
post #1 of 22 Old 05-03-2006, 01:04 PM Thread Starter
mkalcevic
Guest
I was just at the dealer getting my oil changed (I would have DIY, but it was free) and they said the diff. fluid was dirty and needed changing and wanted money that I didn't feel I had to give them. I trust them in saying it was dirty even though I only have 15k on it (stock '05 6cyl) since I'll check it out for myself before paying anything as I have done before there. I have a basic comprehension of how changing it is done, but a couple minor details I need polished over. First, what brand/weight and how much should I get? Synthetic or "natural"? Second, what brand of RTV? Third, is there any kind of spray and/or trick to cleaning out the old crap? Forth, when they say to fill it up until it comes out of the hole, are they talking about the drain hole? And, last, what is the torque for the cover bolts?
mkalcevic is offline
post #2 of 22 Old 05-03-2006, 01:29 PM
sctigerjeep
Guest
you shouldn't really need to use anything to get the old stuff out, just take the diff cover off and let it run into a catch pan. after all the bolts are removed, if the cover doesn't come off, just push a flat head screwdrive between the cover and the diff and pry b/c you may need to break the seal of the old RTV. use the same screwdriver to scrape all the old RTV off, then put down a new bead of RTV (i use permatex, but the brand doesn't really matter). put the cover back on and torque the bolts to 30 ft/lb (i'm pretty sure) and remove the drain plug. go ahead and buy two things of 80W90 gear oil (synthetic vs. non-synthetic is all about preference, as is brand), because one is usually just short of being enough. fill the diff via the drain plug until the oil is right underneath the hole. put the drain plug back in and be on your way.
hope that helps
sctigerjeep is offline
post #3 of 22 Old 05-03-2006, 02:00 PM
GSW
You can use brake cleaner to help you get the old "dirty" oil out. At 15k it wouldn't hurt to swap out the oil anyway, but I'm a little curious how they determined it was dirty, esp. if they were only doing an oil change.
92 YJ
GSW is offline
post #4 of 22 Old 05-03-2006, 02:08 PM
sctigerjeep
Guest
most oil places check your diff oil and tranny fluid every time you go in for an oil change b/c they wanna get you to pay $80 for a $10 job. valvoline told my sister she needed to get hers changed in her TJ and it would be $100 for both axles... i told her to bring it to me and i'd do it for $50, haha.
post #5 of 22 Old 05-03-2006, 02:27 PM
UCTJ
UCTJ's Avatar
checkout www.4x4xplor.com for a detailed writeup on changing your diff fluid. I myself use brake cleaner to clean the inside of the diff out once the fluid is drained, it also helps to just run it around the block before you do the drain to warm not get it scolding hot, the gear oil...drains faster....
UCTJ is offline
post #6 of 22 Old 05-03-2006, 02:42 PM
03jeeper78
03jeeper78's Avatar
Maybe Rubicon D44's have drain holes, but the other differentials don't.. just a fill hole. It's 30ft-lbs for the cover bolts on every diff and 25 for the fill plug on a D30.
'03 Bright Silver Metallic TJ Sport
BSMCCEP Club Member #45
Stock: 4.0L I6:5-speed:3.07 gears:D35 with Trac-Loc:15x7 Ecco wheels:Dual Top Group
Mods: 30x9.5 BFG A-T T/A KO's:JKS Quicker disconnects:Rock-It Man rocker guards:Jeep Medic oil pan/tranny skid:Kilby steering skid:Warn D30 diff guard:C4x4 D35 diff guard:Rusty's radiator guard:Skid Row LCA skids:SilverStar headlights and fogs:Hidden Hitch class III receiver:Old Realistic 40ch CB:2' Firestik II:Arizona Rocky Road tailgate antenna mount
Next : Jeeperman rear bumper
'06 Candy Orange Honda Shadow Spirit 750
03jeeper78 is offline
post #7 of 22 Old 05-03-2006, 02:53 PM
sctigerjeep
Guest
any fill hole is a drain hole if you have a pump. sheesh, lets be a little more technical here.
post #8 of 22 Old 05-03-2006, 02:58 PM
Rocky529
Rocky529's Avatar
Originally Posted by sctigerjeep
you shouldn't really need to use anything to get the old stuff out, just take the diff cover off and let it run into a catch pan. after all the bolts are removed, if the cover doesn't come off, just push a flat head screwdrive between the cover and the diff and pry b/c you may need to break the seal of the old RTV. use the same screwdriver to scrape all the old RTV off, then put down a new bead of RTV (i use permatex, but the brand doesn't really matter). put the cover back on and torque the bolts to 35 ft/lb (i'm pretty sure) and remove the drain plug. go ahead and buy two things of 80W90 gear oil (synthetic vs. non-synthetic is all about preference, as is brand), because one is usually just short of being enough. fill the diff via the drain plug until the oil is right underneath the hole. put the drain plug back in and be on your way.
hope that helps
You're doing a few things backwards.
I would take out the fill plug first before removing the cover to drain your fluid. I would not use a screw driver to scrape the old RTV off. Use a gasket scraper..you don't want gouges in your cover where it meets up with the differential housing.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #9 of 22 Old 05-03-2006, 03:01 PM
RubiconSS
Guest
Look close at your diff. There will be a metal band between two of the bolts. That tag tells you the exact weight and amount of gear oil.
Very handy.
RubiconSS is offline
post #10 of 22 Old 05-03-2006, 03:01 PM
sctigerjeep
Guest
does it really matter when you take the fill plug out? i really don't think so. all of the fluid is gonna come out when you take the cover off anyway. as for the screwdriver... well i don't have a gasket scraper, and as long as you're not putting alot of muscle into it, you're not gonna gouge it. but yes, either way works.
potatoes, potatoes.
p.s. the potatotes thing doesn't work in writing.
post #11 of 22 Old 05-03-2006, 03:05 PM
BChamberlin
BChamberlin's Avatar
potatoes, potatoes.
That's kinda what I was thinking. Maybe he's confusing the fill plug with a drain plug... which my TJ does NOT have.
1994 Wrangler YJ
1999 Wrangler TJ [R.I.P.]
2008 Wrangler X
BChamberlin is offline
post #12 of 22 Old 05-03-2006, 03:09 PM
DestructoJr
The Thin Blue Line
DestructoJr's Avatar
2016 JK Wrangler
The best way to get the old gasket off is to use a torch or a plasma cutter and shave away a small amount of metal from the cover and the housing to ensure a good clean seal afterwards or else air will get into your differentail and cause a bubble in between the gears which over time will stress them unevenly causing a massive failure
Sometimes there's justice, sometimes there's just us
DestructoJr is offline
post #13 of 22 Old 05-03-2006, 03:10 PM
sctigerjeep
Guest
i was using the term fill plug interchangeably with the term drain plug since there IS only 1 plug and it can be used for both draining and filling if you have a pump.
post #14 of 22 Old 05-03-2006, 03:10 PM
03jeeper78
03jeeper78's Avatar
You take the fill plug out first so you know that you won't have any trouble putting fluid back into your diff. That wouldn't be a very pleasant surprise if you drained all of your fluid, RTV'd, and put the cover back on to find out that for some reason you couldn't get the fill plug out!
For some people, sucking the fluid out of the fill plug with a pump might be good enough, but definitely not for me, and it's certainly not the recommended approach.
post #15 of 22 Old 05-03-2006, 03:12 PM
03jeeper78
03jeeper78's Avatar
Some differentials have both a fill and a drain plug.
How do you change your differential fluid? TJShadow TJ Wrangler Technical Forum 16 11-29-2009 07:58 AM
Differential Fluid Change FourbyFour TJ Wrangler Technical Forum 6 06-25-2007 02:12 PM
differential fluid change mfm22 TJ Wrangler Technical Forum 9 12-26-2006 01:19 PM
Differential Fluid Change 04TJTOM TJ Wrangler Technical Forum 3 05-16-2006 09:46 AM
Differential Fluid Change linux24 TJ Wrangler Technical Forum 15 12-06-2004 10:18 AM
