Different springs? - JeepForum.com
post #1 of 4 Old 04-23-2019, 01:46 PM Thread Starter
wranglertec
Different springs?
2003 Wrangler Sport. 4.0 5 speed hard topI did an OME heavy 2 inch coils with Bilstein shocks. Core 4x4 control arms Rough country high clearance crossmember teraflex teralow transfer case. JKS 1.25 bony spacer and motor mounts. I have aftermarket front and rear bumpers winch. After everything was done it came out to 2 1/4 in the front. 3 inch in the rear. It sat low front. High in the rear. The ride really nice. Very little bump steer on crappy roads. After 6 months I decided I wasn’t happy with the nose down look. I added 3/4 daystar front spacers to bring the front up. Centered the axle and steering wheel. What a mistake the added spacers completely changed the ride handling and now have bump steer. What front Springs does anyone recommend to make it even in the front and bring back the nice ride or handling. Or should I remove the front spacers and change out the rear springs.
Sent from my iPhone using Tapatalk
wranglertec is offline
post #2 of 4 Old 04-23-2019, 03:18 PM
jjvw
jjvw's Avatar
What specifically about the ride changed after the spacers went in?
Replacing the spacers with an equivalent lift spring won't change anything. This might be a shock issue. What are the up and down travels from normal ride height?
Bump steer shouldn't be happening unless you also messed with the steering or track bar.
2003 Rubicon
jjvw is offline
post #3 of 4 Old 04-23-2019, 03:25 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Did you align the front after adding the spacers?
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
GOT IT BACK 6/17. 03' Rubicon/Zone 4.25" combo lift with 4" lift coils up front/Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #4 of 4 Old 04-23-2019, 05:35 PM
RDPrimeaux
RDPrimeaux's Avatar
How did you center the axle??
2006 LJ Rubicon
RDPrimeaux is offline
Negative arch SOA Springs Duck Doctor YJ Wrangler Technical Forum 18 04-27-2019 08:53 AM
Which coil springs? williambmac TJ Wrangler Technical Forum 39 10-27-2018 01:46 PM
Jeep sitting lopsided after replacing coil springs. Bzwth WK Grand Cherokee & XK Commander Forum 12 08-07-2018 07:15 PM
Leaf springs.. cherokee00xj XJ Cherokee Technical Forum 5 01-06-2018 06:41 AM
AEV/Nth vs JKS vs (Savvy?) progressive springs Fargo TJ Wrangler Technical Forum 11 12-05-2017 05:31 PM
