did ARB/ OME change spring heights? - JeepForum.com
post #1 of 1 Old 05-17-2021, 11:39 AM Thread Starter
fortz
Hi all, sorry for the simple Q here i'm just confirming I'm ordering the correct combination for my TJ. Currently has some RC 2.5" coils that aren't holding up to the tire carrier and since i'm adding a front bumper as well I want to switch them out.
Front OME spring part #2933 says 1.5" heavy load. I Do already have a .75" spacer that I'll likely use.
rear OME spring part # 2942 says 2" heavy load.
I'm running tire carrier, 33's, will be adding a front bumper but likely no winch for now. Will plan on adding metalcloak fenders front and rear to clear 35's next year when these 33's are worn out.
Is it correct that the springs are rated different lengths? I'm on the straight & narrow here? Thought these coils used to be height matched.
thanks in advance
-k
fortz is offline
arb , ome
