Dash Vents wont work - JeepForum.com
post #1 of 4 Old 09-14-2012, 09:27 PM Thread Starter
BM20
2002 Jeep Wrangler. The defroster works, the floor vents work, just the dash vents wont blow any air. Vacuum lines are hooked up. I checked the actuators behind the dash and found the one on the floor (right above the airbag module/transmission hump) had the black plastic arm broken.
Its in a spot that was super hard to get too but I pulled most of the broken part out. The tip that connects to the door didnt come out. because of where it was, I couldnt just do the screw in fix, no room to get the screw in there.
I found a link on this forum for a replacement arm for a 97-06 TJ. I ordered it and the new one that came said on the package 97-01. It was shorter on the link side and longer on the door side. I e-mailed them and they said it was a mistake, it wouldnt work and they dont make the part I need.
Does anyone know where to get the right lever from?
RUBICON Tomb Raider #953
With a Few Extras...
BM20 is offline
post #2 of 4 Old 09-14-2012, 09:45 PM
JPNinPA
Junkyard
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #3 of 4 Old 09-14-2012, 09:46 PM Thread Starter
BM20
how do you get the new piece out without breaking it? there is only 2 inches maybe of room between the arm and the floor and it points straight down.
BM20 is offline
post #4 of 4 Old 09-14-2012, 10:00 PM
JPNinPA
http://www.jeep4x4center.com/air-con...rangler-tj.htm
JPNinPA is offline
center console vents wont work when pushing air through a 2002 burtron90 TJ Wrangler Technical Forum 0 04-01-2012 10:09 AM
floor vents wont work newjeeper369 YJ Wrangler Technical Forum 0 12-08-2010 05:45 PM
Running lights and Dash lights wont work!? Help nield13 YJ Wrangler Technical Forum 4 12-12-2009 02:22 PM
Dash light wont work jeepin16 TJ Wrangler Technical Forum 5 11-19-2009 01:41 AM
Replaced Dash bulbs and now they wont work Ryan95YJ YJ Wrangler Technical Forum 4 02-11-2009 07:08 PM
