Dana 35 lsd rear diff, Castrol oil? - JeepForum.com
 1Likes
  • 1 Post By mate44
post #1 of 9 Old 01-27-2020, 04:24 AM Thread Starter
mate44
Hi. In progress of changing oil in the diffs now. Quick question: Is it ok to use Castrol Axle Z Limited slip 90 in Dana 35 rear with LSD?
https://www.classic-oils.net/MobileD...p?Prod_ID=4656
Thanks!
M
mate44 is offline
post #2 of 9 Old 01-27-2020, 07:32 AM
sycboi
I believe that will work just fine. It says it is GL-5 rated...
SuperBeast, enforcer for the Mopar Mafia ̿ '̿'̿\̵͇̿̿\з=(̪●)=ε/̵͇̿̿/'̿'̿ ̿
sycboi is offline
post #3 of 9 Old 01-27-2020, 07:41 AM
2jhanna
Yes, many GL5 fluids now contain the lsd additive built in. If your axle doesn't have lsd, it's still ok to use these fluids, it won't hurt anything.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #4 of 9 Old 01-27-2020, 09:31 AM Thread Starter
mate44
thank you:-)
mate44 is offline
post #5 of 9 Old 01-27-2020, 09:31 AM Thread Starter
mate44
Thank you:-)
mate44 is offline
post #6 of 9 Old 01-27-2020, 09:50 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It's hard to find a GL-5 gear lube without the limited slip additive.
Jerry Bransford is offline
post #7 of 9 Old 01-27-2020, 10:15 AM Thread Starter
mate44
It's hard to find a GL-5 gear lube without the limited slip additive. <img src="https://www.jeepforum.com/ubb/smile.gif" border="0" alt="" title="Smilie" class="inlineimg" />
I did put this in the front: https://m.ebay.co.uk/itm/axle-epx-80...epid=824307777
Does this contain the additive and can I use it in the rear diff? What choise do you think would be the better one? The EPX or the AXLE LS 90?
mate44 is offline
post #8 of 9 Old 01-27-2020, 10:40 AM
Jerry Bransford
Administrator
It doesn't appear the EPX contains the required friction modifier additive. So for your rear limited slip differential equipped axle I'd definitely go for the Axle LS-90 which does.
post #9 of 9 Old 01-27-2020, 12:57 PM Thread Starter
mate44
I did put this in the front: http://m.ebay.co.uk/itm/axle-epx-80w...epid=824307777
I will go for the Axle LS-90. Thank you for all your help! It is much apreciated.
Jerry Bransford likes this.
mate44 is offline
