Dana 35 axle vent - JeepForum.com
post #1 of 4 Old 08-23-2019, 09:29 AM Thread Starter
ChadHine
ChadHine's Avatar
Dana 35 axle vent
I have a 2003 TJ and the rear axle vent tube was missing when I bought the Jeep. Bought the Mopar fitting from the dealership, appears to be too short to go through the brake line Tee block and into the axle vent threads. Has anyone experienced this? For now, I pushed the brake line out of the way enough so I could screw in the vent fitting however oil leaks out. Any help would be appreciated.
ChadHine is offline
post #2 of 4 Old 08-24-2019, 10:46 PM
mukluk
mukluk's Avatar
Can't say I've heard this problem before. Do you have any pictures you can post up or at least some measurements of the components you have?
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 4 Old 08-25-2019, 11:14 AM
MoFarmBoy
Is it for a JK? I think they're shorter since they don't secure a block.
MoFarmBoy is offline
post #4 of 4 Old 08-25-2019, 11:31 AM
2jhanna
Have you checked the fluid level of the rear axle. Pull the rubber plug, and see if overfull.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
