Dana 30 & 35 Problems? - JeepForum.com
post #1 of 8 Old 07-31-2014, 11:31 AM Thread Starter
MountainManJr
Recently purchased my first vehicle, 2006 Jeep TJ X 4.0 with the NSG370 Transmission. Now I've heard a lot about the dana 35 having problems, I'm not looking to do heavy off roading. but i would like to put 33s on it. Would this cause strain for the axles? And if so, what ways can i fix them, Any opinions are welcome.
Thanks
MountainManJr is offline
post #2 of 8 Old 07-31-2014, 12:28 PM
JWebber
Find out what gear ratio you have. That would be a start!
JWebber is offline
post #3 of 8 Old 07-31-2014, 12:41 PM
Macanator
Supporting Member
Macanator's Avatar
You'll be just fine with 33" tires on the factory axles. The D35 is just fine for most of the world, it's issues really come to life when people start wheeling them hard.
I've seen 35" tires on a D35 with a Super 35 kit survive SOOOOO much that it really changed my opinion of the D35.
It's just a matter of knowing it's limitations but with 33's on a driver, you will have no issues. But you may want to consider a gear ratio change at the same time you add the tires because it will be a DOGG with the factory ratio.
Mac McMillan
revolutiongear.com
Macanator is offline
post #4 of 8 Old 07-31-2014, 01:07 PM
joe_jeep
With skinny light 33s, and you taking it real easy, it might live a while. One good dump of the clutch on 33s, and all bets are off.
If you end up doing a regear, get a true trac diff, and some decent shafts, it will let the 35 live a long time.
The stock spider gears are horrible. The shafts are not great. If you get rid of those two things, it will be a fine axle.
The install of these parts should be free during a regear. For 33s with a 6sp 4.10 gears are nice. if you already got 3.73 dont bother changing them.
Good luck.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #5 of 8 Old 10-22-2015, 06:39 AM Thread Starter
MountainManJr
Good luck.
Well i have open diffs with 3:07 gears and 33s, and two months ago i lifted her and got the tires on. Looks good but the fuel economy is killing me. I need to regear but do not have the money
post #6 of 8 Old 10-22-2015, 08:54 AM
s14sh3r
Are you using 6th gear? I have 3.07's and a 5 speed. When I first bought it I used 5th gear and had to pretty much keep it floored to maintain speed in 5th. I finally stopped using 5th gear altogether, treating it like a 4 speed and I'm able to go down the road much better and my mileage improved somewhat.
s14sh3r is offline
post #7 of 8 Old 10-22-2015, 11:55 AM Thread Starter
MountainManJr
I can use 6th gear comfortably going down a level highway or downhill highway. Will go up slight inclines in the highway but will have to downshift into 5th eventually.
post #8 of 8 Old 10-22-2015, 08:07 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
What speed do you run at on the highway?...
Knuckelhead is offline
axle , dana 30 , dana 35 , problems
