d30 for 44 swap, plus bb questions - JeepForum.com
post #1 of 10 Old 01-07-2018, 07:14 PM Thread Starter
flys_yj
flys_yj's Avatar
my daughter was in an accident and bent the d44 in her 03 rubi. haven't been able to source a reasonable housing and her budget is small, so i am thinking a d30 to get her back on the road. new control arms and steering tie rods have been purchased. i suspect new rotors will be needed also. are the calipers the same? did the 4cl come with 4:10's? was also thinking a 2" bb lift and shocks while it is all torn down that far. anything i need to know? additional parts? suggestions?
flys_yj is offline
post #2 of 10 Old 01-07-2018, 07:22 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your TJ D44 brakes are identical to those made for D30's so they'll bolt right up. Everything outside of their center pumpkins is identical.
Jerry Bransford is offline
post #3 of 10 Old 01-07-2018, 07:25 PM
jeepinjoeu
jeepinjoeu's Avatar
Did she bend the actual axle housing/tubes? Have any pics? I'd be more worried about frame damage if she hit something hard enough to bend the axle. It would be a good idea to do a bb lift and shocks well you're swapping axles. Some 4 cyl came with 4.10s, you will have to look at the tag of the new axle you buy to be able to tell the gear ratio.
01 TJ, 4.0, Auto, 33's, 3.5in RE Lift (SOLD)
01 TJ, 4.0, Auto, 35's, Locked Dana 44's, 5.38s, Atlas 2 4.3:1 (Crawler)
99 TJ, 4.0, Manual, 31's (Project)
96 ZJ, 5.2 V8 (DD)
jeepinjoeu is offline
post #4 of 10 Old 01-07-2018, 07:30 PM Thread Starter
flys_yj
flys_yj's Avatar
frame seems ok. made a couple of cross measurements and all were good. she bent the right side tube at the 'C' end. is re tubing that side an option? or are these parts as unicorn as an entire housing seems to be?
flys_yj is offline
post #5 of 10 Old 01-07-2018, 08:47 PM
biffgnar
biffgnar's Avatar
Finding a replacement Rubi D44 front only is unlikely. They almost always trade as a set and they trade at stupid prices.
biffgnar is offline
post #6 of 10 Old 01-08-2018, 07:54 AM
NotURMailman
NotURMailman's Avatar
I would source an HP30 from an XJ with 4.10 gears if you decide to swap to a D30, probably easier to find that a 4 cyl TJ axle.
You can use car-part.com to locate one.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #7 of 10 Old 01-08-2018, 09:37 AM
zackcj7
I don't know if they are still available, but for a while you could get just the Rubicon axle housings from the Chrysler parts department. Both my front and rear Rubi housings were purchased this way. I may still have the tags with the part numbers somewhere.
zackcj7 is offline
post #8 of 10 Old 01-08-2018, 11:15 AM Thread Starter
flys_yj
flys_yj's Avatar
i went to dodge first..not available right now and 1800$ when they are. not in her budget.
is an XJ and TJ the same width? Same axle?
flys_yj is offline
post #9 of 10 Old 01-08-2018, 03:09 PM
biffgnar
biffgnar's Avatar
They are basically the same, except that pre-2000 the XJ's are high pinion. But I thinking finding a 4.10 geared XJ will be just as hard as finding a TJ one. Most of the XJ ones you'll find will be 3.55.
biffgnar is offline
post #10 of 10 Old 01-08-2018, 03:39 PM
wvjeepguy81
Just get on car-part.com and do a search. I found a 4.10 hp30 locally through that site, as well as my replacement frame, my superduty tons, and a few smaller parts.
wvjeepguy81 is offline
