Cylinder 5 misfire - JeepForum.com
post #1 of 17 Old 02-10-2006, 11:34 AM Thread Starter
WVMIKEsTJ
Guest
Cylinder 5 misfire
Here is the specs.
2000 jeep wrangler
4.0L
115,000 miles
oil/filters changed and everything greased religously
a couple weeks ago enigne light comes on and it say "engine 3 and 5 misfire." Last year when this happened I cahnged plugs and all was fine, but this time I cahnged plugs with the NGK plugs and all of a sudden the light stayed off for about a week and it came back on. Nothing seems weird with how it runs. Since I put the new plugs in it runs smoother than ever and does not act weird at all. On the computer t the dealership i watch the counter count the misfires.
What could it be?
WVMIKEsTJ is offline
post #2 of 17 Old 02-10-2006, 11:35 AM
RockRunner85
Injectors can be the cause of a thrown misfire code.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #3 of 17 Old 02-10-2006, 11:39 AM
Why J?
Why J?'s Avatar
Could be that alot of people have trouble with this type of plug in a Jeep. The best plug would be a Champion truck plug. This plug was designed to run in a Jeep.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #4 of 17 Old 02-10-2006, 11:51 AM
jeeptj19992001
wires go bad as well
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline
post #5 of 17 Old 02-10-2006, 11:59 AM
meengineer2006
Guest
IMO Champions are worthless. Bosch or NGK are the plugs to use. I don't even use Champion in my lawn mower. Repeated bad experiences with Champions, I'm not hating on anyone.
meengineer2006 is offline
post #6 of 17 Old 02-10-2006, 12:25 PM
SeanCucf
SeanCucf's Avatar
bosch???? have you tried them in a 4.0? Please don't use those.
another vote for champion(i use the platinums however and don't know the part #)
On topic: Could be the coil pack too. I never looked to see if you can move the packs around on the rail, but switch #5 with another pack and see if the misfire changes cylinders. Or do the same thing with the injector. Maybe you can eliminate problems and narrow the search down.
sean
SeanCucf is offline
post #7 of 17 Old 02-10-2006, 01:40 PM
dcafaro
Guest
Another vote for do not use Bosch plugs (especially platinums in the 4.0) you are hear by forbidden!!! I would run some seafoam through the intake and give a good cleaning to the injectors and see if that helps anything first, just make sure you're able to change the oil afterwards.
dcafaro is offline
post #8 of 17 Old 02-10-2006, 01:44 PM Thread Starter
WVMIKEsTJ
Guest
I ran the foam from chrysler through it, and put some Marvel Mystery oil into the oil the other day. So tonight I am going to change out the cylinder 5 plug. If that does not work I am going to switch injectors.
post #9 of 17 Old 02-10-2006, 02:40 PM
mcfoley
Guest
Keep me posted, I have a misfire code too... I replaced the plugs, wires, etc and replaced the injector too...Can't diagnose.
mcfoley is offline
post #10 of 17 Old 02-10-2006, 02:46 PM
TJ_Firefighter
Guest
not to steal the post but what's the deal against bosch platinum plugs??? what about auto lite platinums? are they ok to use?
TJ_Firefighter is offline
post #11 of 17 Old 02-10-2006, 04:29 PM
ak-rider
After 185K miles I just started having misfire codes pop up. Seems I have a worn distributer that may be causing it. I haven't swapped to a new one yet, so it may not have anything to do with it, but.... might want to check.
ak-rider is offline
post #12 of 17 Old 02-10-2006, 04:49 PM
o2tj
o2tj's Avatar
dont swap the dist. just go to your local auto parts store and pick up a new pick up for it. It sits under the rotor in the dist. after the install flash your computer. If you dont the code will still pop up after you change the parts.
o2tj is offline
post #13 of 17 Old 02-10-2006, 05:08 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
thought in 2k they switched to coil pack??? may be wrong though
RnEmOvr is offline
post #14 of 17 Old 02-10-2006, 05:17 PM
o2tj
o2tj's Avatar
1/2 and 1/2 some came with dist and some came coil packs, thought I read he had wires? if not never mind..................lol
o2tj is offline
post #15 of 17 Old 02-10-2006, 06:02 PM
adp5025
Guest
Not sure what the problem is but jeeps dont like NGK and any other brand like that.
Replace with:
Champion truck plugs or Autolite single Plat.
adp5025 is offline
Cylinder Misfire? help MDJeep7 TJ Wrangler Technical Forum 2 05-30-2009 09:12 PM
Misfire on cylinder 3....not sure what else to do simplybao TJ Wrangler Technical Forum 11 08-10-2008 09:44 AM
Cylinder 2 misfire dead cylinder plenty of fuel Mel16m TJ Wrangler Technical Forum 10 11-27-2007 10:52 AM
Cylinder Misfire? fundabug TJ Wrangler Technical Forum 5 02-11-2007 02:45 PM
Cylinder Misfire, Help jeepdan TJ Wrangler Technical Forum 3 08-04-2002 02:38 PM
