Custom Tonneau Prop Writeup - JeepForum.com
post #1 of 16 Old 05-17-2007, 06:08 PM Thread Starter
connor014
I was tired of my tonnea cover sagging and collecting rain so I finally decided to do something about it. This is a very simple fix which some of you may have done but I figured I would make a writeup about it to save you some time from cutting the dimensions and finding out what works.
Materials Required:
2-1/2" Sticks of PVC
4-1/2" T Fittings-4
1-Krylon Fusion (Optional)
6-Beers (Must Have)
First off cut two sections of PVC at 58 1/2". These will be the cross members that will bend and push the top up. You will also need to cut 2-9 1/8", 2-13 1/4", 2-10 1/2" Pieces. These will make the sides of the structure. Once you have all of these cut assemble them. If you want you can hit it with a couple of coats of your favorite spray paint (I prefer the Krylon Fusion). Fit it all together and bend it into place. I made all the dimensions to fit perfect (with some trial and error) so it will be very simple for you. This should fit in your jeep perfectly (mine is a 97TJ). This is a quick and cheap fix (Under $15) and works great. Enjoy......
Here are a few pics:
connor014 is offline
post #2 of 16 Old 05-17-2007, 06:18 PM
happycamper
1986 XJ Cherokee
good idea
Gone but not forgot. 2000 Sahara 4.0, auto, 4"rock krawler x factor long arm, 33x12.50x15 M.T. Mtz, M.T. classic lock rims,30/44 limited slip, land runner safari rack, land runner front, and rear bumpers, warn 8000i winch, cobra cb, jks 1.25" bl, brown dog 1" mm lift.AA sye, J.E. Reel drive shaft, Aussie locker, Rock Crusher front cover
happycamper is offline
post #3 of 16 Old 05-17-2007, 07:42 PM
JEEP97TJ
Great idea, nice write-up looks good
Blacksburg, VA
JEEP97TJ is offline
post #4 of 16 Old 05-17-2007, 08:19 PM
rmb2485
rmb2485's Avatar
tried to make it click free but it didn't work. oh well... looks good tho!
rmb2485 is offline
post #5 of 16 Old 05-17-2007, 09:05 PM
Nefarious
nice write up!
2005 Rubicon Unlimited Sahara Edition 605/1000
2001 WJ Limited - Sold
Nefarious is offline
post #6 of 16 Old 05-17-2007, 09:13 PM
04WranglerX
Guest
04WranglerX is offline
post #7 of 16 Old 05-17-2007, 09:14 PM
abnormal
Platinum Member
abnormal's Avatar
Cool!
So it just sits on the fender wells? I will have to do this.
abnormal is offline
post #8 of 16 Old 05-18-2007, 12:12 PM Thread Starter
connor014
yeah it sits in there perfect....i made the side lengths to fit right behind the roll bar to a little piece of metal that sticks out on the body right by the roll bar at the rear on the side....thanks for posting those pics also
post #9 of 16 Old 05-18-2007, 01:37 PM
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
Nice job...simple, cheap, effective! Everything a Jeeper likes!
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig:
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline
post #10 of 16 Old 05-18-2007, 02:22 PM
mjkolb02tj
Guest
I will be making one of these. Now if I can just figure one out so the bikini top won't collect water I will be set.
mjkolb02tj is offline
post #11 of 16 Old 05-18-2007, 03:04 PM
NOVATJ
NOVATJ's Avatar
1996 TJ Wrangler
For the bikini use a piece of 1/2" PVC with PVC supports on each end. The support pieces look like a T but the section with 2 open ends is a half pipe. You need to get the support pieces to fit the diameter of the roll bar.
Hope that makes sense
1984 CJ7 - Lost to fire
1997 TJ SE - 2.25" Budget Boost, Hydros, 31" Sigma Stampedes
NOVATJ is offline
post #12 of 16 Old 05-18-2007, 04:14 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
looks like a project for Sunday
97 TJ 37s custom long arm
Gen right stretch tank
03 TJ buggy project. Stretched tub to LJ, Goat Built chassis, tons 42 pit bulls
04 QCLB 4wd Cummins tow rig
24 Gooseneck PJ trailer
JeepRocks86 is offline
post #13 of 16 Old 05-21-2007, 07:23 AM
mjkolb02tj
Guest
Makes sense to me, thanks for the help. Looks like I will be headed back to Home Depot.
post #14 of 16 Old 05-24-2007, 04:11 PM Thread Starter
connor014
yeah i need to do the bikini also....if you do it post some pics!
post #15 of 16 Old 05-24-2007, 10:02 PM
JeepRocks86
what is it, about 16 feet total, of pipe but that's on the generous side so you could probably get away with 15'. Its actually closer to 15.25 feet so you would need to buy atleast 16 feet depending on the length sold in. I think tomorrow I have a new project.
Simple, quick and INEXPENSIVE tonneau Prop maddiver TJ Wrangler Technical Forum 8 07-28-2018 01:15 PM
Tonneau Cover Not Fitting Very Well Any Custom Setups? connor014 TJ Wrangler Technical Forum 7 04-25-2007 03:03 PM
Prop for your Duster/Tonneau Eric_D YJ Wrangler Technical Forum 0 06-01-2006 03:18 PM
Custom dash writeup finished JeepCrawler_98 TJ Wrangler Technical Forum 4 08-16-2004 01:35 AM
Top Prop???? jason12 YJ Wrangler Technical Forum 2 12-02-2003 09:34 PM
