Currie CA's can't adjust enough for the new ultra-high TC skid - JeepForum.com
post #1 of 28 Old 12-27-2010, 12:23 PM Thread Starter
ImaginaryFriend
ImaginaryFriend's Avatar
Well it seems that I can't get the rear dialed in with this new UCF ultra-high clearance skid and Currie control arms. I have the lower arms as short as possible and the uppers are out their max of 3/4" thread showing. I still have a 3-4 degree difference between the DS and pinion. The pinion still needs to point further up.
Any thoughts? I'd rather not have to buy new arms. Is it really unsafe to go past the 3/4" recommendation of Currie? Not sure how much more extension would be needed.
ImaginaryFriend is offline
post #2 of 28 Old 12-27-2010, 12:50 PM
WV-TJ
Been seeing alot about this lately, but I have not had to deal with it. One solution may be to take the lower arms off and cut maybe a half inch off of the threaded female end and reinstall. That should give you more adjustment. I still do not know why currie does not make their arms just a little bit longer.
WV-TJ is offline
post #3 of 28 Old 12-27-2010, 12:57 PM
dcope17
dcope17's Avatar
You can prolly get away with more than 3/4 thread showing on the UCAs cause you should never have the vehicle weight sitting on the like you do the lowers when your hung up on them.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #4 of 28 Old 12-27-2010, 01:01 PM
Benderff
Benderff's Avatar
Before you start cutting anything I would call Currie, wait for Blaine to chime in, and/or read the other threads about this. Just to confirm your lower arms are Currie as well?
https://www.jeepforum.com/forum/f9/cu...ssion-1144932/
Benderff is offline
post #5 of 28 Old 12-27-2010, 01:27 PM Thread Starter
ImaginaryFriend
Yep, all Currie arms (from Savvy). They had plenty of adjustment for my super short SYE and stock skid, but not with my new UCF skid.
I've read some other threads about Currie arms being short, but it seems like most were trying to run the lowers at stock length or longer.
I definitely am not cutting anything.
I'll wait for Blaine's input. I guess Currie makes them at custom lengths too?
post #6 of 28 Old 12-27-2010, 01:32 PM
Benderff
Benderff's Avatar
I'd call Currie! I have always had great customer service from them. Are you running Currie springs also? With the changes are your rear wheels centered in the wheel wells?
Benderff is offline
post #7 of 28 Old 12-27-2010, 01:41 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Do you have vibes? Try driving it. I had to lower my pinion on the LJ cause there was a slight vibe I couldn't get out until I lowered the pinion angle. Otherwise, bring the lowers in one turn and look at it and drive it.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #8 of 28 Old 12-27-2010, 01:48 PM Thread Starter
ImaginaryFriend
BDS 3" springs. I haven't driven it yet, since I was trying to get the angles to match. I can't move the lowers in any further.
I haven't bothered with centering the rear wheels since I have to run the lowers as short as possible to get even this close (3-4 degrees off).
post #9 of 28 Old 12-27-2010, 02:13 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Drive it to see if you have any vibes. If not you'll be good to go! I've notice on the last two Jeeps that I needed the pinion to be lower than I thought.
Gerald
Like us on Facebook
Savvy is offline
post #10 of 28 Old 12-27-2010, 03:27 PM Thread Starter
ImaginaryFriend
Thanks for all the pointers, I really do appreciate it.
I'm just the OCD type. Since I've been told to set the angles to match (or maybe pinion 1 degree lower for axle wrap) I can't help but think that even without vibes I'm not doing it "correctly" and I'm causing wear and tear.
This is still my DD and things like this don't help my mental issues!
post #11 of 28 Old 12-27-2010, 05:58 PM
viperbluelx
viperbluelx's Avatar
1980 CJ7
This is not what I need to hear.
viperbluelx is offline
post #12 of 28 Old 12-27-2010, 06:20 PM
4.0l sahara
rokmen has cv upper arms that are longer and have jj's at both ends.
4.0l sahara is offline
post #13 of 28 Old 12-27-2010, 07:04 PM
RubiconRazorbac
RubiconRazorbac's Avatar
So does Currie. Just pick up the phone during business hours and let them know.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #14 of 28 Old 12-27-2010, 07:32 PM
Stonz
Stonz's Avatar
I have the UHC UCF stuff, new rear DS in the garage. New Currie CAs should be here Wed.
.....waiting to hear more on this
06 Rubicon,BL,35s,alot of Currie,Rokmen,Savvy,UCF TT,Tom Woods,winch,brake upgrade,antirock,outboard Ranchos, coil reloc, etc
On-On!
Stonz is offline
post #15 of 28 Old 12-27-2010, 08:58 PM Thread Starter
ImaginaryFriend
Well, it's vibe free at it's current setting. Drove around the block a few times and I set the frame up on jack stands and let the rear axle droop as far as the shocks allow. I spun everything by hand and in gear running and I can't see or feel anything binding. Looks pretty smooth actually, even at uneven angles.
Should I just leave it at this point? If I have no vibes should I worry about the uneven angles (3-4 degrees off)? It still bothers me a bit though. I'll take a look at it again tomorrow and see if slightly longer UCA's will put my mind at ease.
Now I have a click-click when driving. I can't get it to do it on jack stands, but I think my 2 u-joints at my rear CV end of the DS are a little loose and maybe making the sounds (I can barely wiggle them, but they are loose since I can get a tiny amount of movement). The axle end u-joint was really loose so I just went out an hour or so ago and replaced that one. Funny, I never noticed them being loose before. It definitely seems to be coming from the rear, and it will do it even when barely moving up my drive in first gear.
I guess the higher angles made things move a little differently and now they are making noises? They were noise free a couple days ago before the tummy tuck.
UCF Ultra High Clearance Skid Install guht TJ Wrangler Technical Forum 52 10-10-2011 02:40 PM
currie jj ca's. Best price and technical discussion 4.0l sahara TJ Wrangler Technical Forum 47 12-26-2010 06:01 PM
Anyone running the UCF ultra-clearance skid on an 03-06? viperbluelx TJ Wrangler Technical Forum 2 12-01-2010 06:52 PM
Rear Pinion - Currie CA's Lowers UncleWilson TJ Wrangler Technical Forum 24 11-04-2010 11:55 AM
What's the best way to adjust front CA's? RVA_TJ06 TJ Wrangler Technical Forum 3 12-20-2008 10:21 PM
