Cummins 4bt - JeepForum.com
post #1 of 22 Old 01-20-2016, 11:27 PM Thread Starter
Dbyman01
Cummins 4bt
Hey everyone I was considering putting a Cummins 4bt into my 97 tj sport I was wondering if anyone on here has done that and if they have could you tell everything you needed thanks
Dbyman01 is offline
post #2 of 22 Old 01-21-2016, 05:20 AM
bobjp
This has been done, and there are many write ups on the internet. It's extremely expensive, and not easy.
Honestly, if this is how you start such a monumental task, it's unlikely to be something you'd actually do.
97 TJ sport.
bobjp is offline
post #3 of 22 Old 01-21-2016, 09:21 AM Thread Starter
Dbyman01
Okay thanks
Dbyman01 is offline
post #4 of 22 Old 01-21-2016, 10:01 AM
biffgnar
biffgnar's Avatar
One of the most talked about, but rarely done swaps when it comes to TJs. Weight alone would end any thought about it for me.
biffgnar is offline
post #5 of 22 Old 01-21-2016, 04:20 PM
sduncan
sduncan's Avatar
See above...almost 800 lbs hanging off the front is just too much for a short wheelbase TJ...especially over OEM axles..
'98 TJ, 5.7 HEMI,
sduncan is offline
post #6 of 22 Old 01-21-2016, 11:54 PM Thread Starter
Dbyman01
Okay thanks for the advice guys I'm 14 its my first vehicle just looking for some ideas and advice
Dbyman01 is offline
post #7 of 22 Old 01-22-2016, 05:17 AM
bobjp
That's cool. You should definitely do some challenging work on it. That's the only way to learn. Get it running as it is, and then make some mods as you go. Keep it simple at first.
It's just that the Cummins swap is very expensive, very hard, and of debatable value. There are so many peripheral things to consider. It's not a good way to start with your first vehicle.
97 TJ sport.
bobjp is offline
post #8 of 22 Old 01-22-2016, 06:45 AM
Ben
Ben's Avatar
There's a lot of things you can do to a 20 year old TJ that will teach you a lot about vehicles and working on them.
Maintenance, replacing bushings/bearings, frame cleaning/painting...
If you really want a 4BT TJ, you've got a lot of research to do, and you're probably looking at $10k.
In the mean while, if you're going to make your TJ into one, there's a ton of other things you could do first, with a diesel Wrangler being the ultimate goal.
Most questions have been asked already, don't let that stop you from asking one, but you already have access to a ton of info without waiting for replies.
Ben is offline
post #9 of 22 Old 01-22-2016, 08:56 AM Thread Starter
Dbyman01
That's great thank you guys very much I've already done some work on it I installed a 4 inch suspension lift and a 2 inch body lift
Dbyman01 is offline
post #10 of 22 Old 01-22-2016, 09:49 AM
ravenworks
ravenworks's Avatar
The Mercedes Diesel is interesting.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #11 of 22 Old 01-22-2016, 10:18 AM
biffgnar
biffgnar's Avatar
I think this one is interesting, but better save your pennnies in advance: http://www.cotybuilt.com/
biffgnar is offline
post #12 of 22 Old 01-22-2016, 07:32 PM Thread Starter
Dbyman01
How much does the Mercedes diesel weigh compared to the 4bt?
Dbyman01 is offline
post #13 of 22 Old 01-22-2016, 10:20 PM
ravenworks
ravenworks's Avatar
I would Imagine a lot less considering it's a car, Google JF for it because it's been done.
Personally,any way you look at it this endevor is going to cost a lot of money.
Semper-Fi "81-84"
I.U.O.E. - 18
post #14 of 22 Old 01-24-2016, 09:31 AM Thread Starter
Dbyman01
Yeah thanks for all the help fuys
Dbyman01 is offline
post #15 of 22 Old 01-24-2016, 09:32 AM Thread Starter
Dbyman01
Guys*
Dbyman01 is offline
