Crankcase Cover Breather Housing - JeepForum.com
post #1 of 4 Old 03-01-2009, 03:14 PM Thread Starter
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
My 2004 TJ's crankcase seems to be leaking some oil at the rubber housing. When I grab it and move it it leaks oil. Would a new rubber housing provide better seal and reduce oil seepage?
2009 JK Rubicon, 2004 TJ now gone
2019 Mustang GT 6 Spd DD
2017 Porsche 718 Cayman
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine, LCA & Evap Skid; Rock Hard Gas Tank Skid; Warn Stainless Diff Skids, Pull-Pal, Uniden 520XL CB, Aeroforce Interceptor, Valentine 1
Ouray - TJ-8/07
Moab - TJ: 4/06, 5/08, JK: 4/09, 5/11, 4/13, 5/16, 4/17, 5/18
Rubicon - TJ-9/08
Thunderstrike is offline
post #2 of 4 Old 03-01-2009, 03:23 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Yes those get extremely brittle and will crack over the years.
GOLENJEEPTJ is offline
post #3 of 4 Old 03-01-2009, 03:24 PM
GOLENJEEPTJ
You will probably end up snapping them while removing them.
post #4 of 4 Old 03-01-2009, 03:32 PM Thread Starter
Thunderstrike
2009 JK Wrangler
OKAY; will exercise care when removing. Going to a dealer to order two new ones.
Ouray - TJ-8/07
Rubicon - TJ-9/08
Removing crankcase breather tube? 19OlllllllO41 TJ Wrangler Technical Forum 8 09-28-2019 10:42 AM
Crankcase Breather Element (2.5L) cooltc2004 YJ Wrangler Technical Forum 4 01-08-2011 09:35 PM
Crankcase breather? Gooch YJ Wrangler Technical Forum 1 10-30-2009 10:54 AM
Can I.. plug up the crankcase breather? SHJeeper YJ Wrangler Technical Forum 9 02-24-2009 04:50 AM
Need Help. Broken Crankcase Breather hose routten TJ Wrangler Technical Forum 2 09-10-2006 09:39 PM
