cracked manifold - JeepForum.com
post #1 of 7 Old 03-18-2010, 08:58 AM Thread Starter
jebmccall
1997 XJ Cherokee
cracked manifold
so as some of you guys know im looking at getting a very nice 99 shara for 3500. the manifold has been cracked for atleast 10000 miles. how would i check for burnt valves, and if it does have burnt valves what kind of issues would it cause. i have driven this jeep a good bit, it has power, runs really good. does not miss or run rough. gas milage seems pretty crap, even still though it has 4.10s and a 5spd.
jebmccall is offline
post #2 of 7 Old 03-18-2010, 09:08 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
2020 J-Series Truck
A compression test will tell you.
Wheelin98TJ is offline
post #3 of 7 Old 03-18-2010, 09:18 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
My 98' just made a slight ticking noise that was more noticeable when driving under bridges.I replaced it with a $75 ebay cheapo and never had a problem.
TheBoogieman is offline
post #4 of 7 Old 03-18-2010, 09:24 AM Thread Starter
jebmccall
1997 XJ Cherokee
if i do wind up getting it i will put an apn header on. the only thing i am worried about is it having some engine problems in the future due to this issue.
post #5 of 7 Old 03-18-2010, 09:28 AM
TheBoogieman
I doubt it.The PO drove mine for over a year with it cracked.I know people that have never fixed their cracked manifolds.
post #6 of 7 Old 03-18-2010, 09:34 AM
Wheelin98TJ
JEEP FREAK
2020 J-Series Truck
I would consider a different header.
You'll probably have cracking problems with the APN header too.
The 2 piece headers/manifolds are the way to go. The 1 piece design is too long and it does not allow enough flex and variation between the first and last cylinders like a 2 piece manifold/header can.
post #7 of 7 Old 03-18-2010, 09:45 AM Thread Starter
jebmccall
1997 XJ Cherokee
hmm, ok guess i shouldnt have put the apn on the cherokee. one thing i noticed with the apn is its alot better built, but didnt hjave the elbows.
Cracked manifold on 98 TJ... fishbone98 TJ Wrangler Technical Forum 8 08-07-2008 09:05 AM
TJ Manifold cracked.... once again!!! phish832 TJ Wrangler Technical Forum 13 10-15-2007 06:28 PM
Cracked Manifold jeep4002 TJ Wrangler Technical Forum 10 06-03-2007 07:57 PM
yup, another cracked manifold.. bryans98tj TJ Wrangler Technical Forum 2 03-26-2007 08:50 AM
Cracked Tj Manifold Ethan03 TJ Wrangler Technical Forum 21 06-05-2006 04:02 AM
