Correct TJ Rubicon differential fluid(s). - JeepForum.com
 4Likes
  • 1 Post By 2jhanna
  • 2 Post By Jerry Bransford
  • 1 Post By joe_jeep
post #1 of 10 Old 08-04-2020, 07:31 AM Thread Starter
Ijeepalone
Prepping for my first DIY differential(s) fluid change on a stock '06 Rubicon, some confusion on the correct fluid to use. Just watched deepdivejeepHD (YouTube) which was great. For the rear Dana 44 axle > Mopar Synthetic Gear & Axle Lub / SAE 75W140 / GL-5, which matches the metal tag on the diff. Deepdive is very thorough and I assume he would mention if the front Dana 44 diff required a different lub...he did not. The metal tag on the front diff sez 80W90.
Deepdive also mentioned that '02-06 Rubicon axles were incorrectly tagged, so a little confused & need some guidance. Last, he also mentioned to NOT add friction modifier...because the Rubicon axles with the lockers do not require this, unlike previous Dana 44's.
If 80W90 is correct for the front axle...just curious, why? Also, any rec's on a good maintenance manual (pdf preferred) that includes the TJ Rubicon thoroughly (not just the base models)?
Thanks in advance!
Ijeepalone is offline
post #2 of 10 Old 08-04-2020, 08:09 AM
2jhanna
Look here
https://www.jeepforum.com/forum/f9/f...cities-489932/
Wheelin98TJ likes this.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #3 of 10 Old 08-04-2020, 10:13 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You want the Factory Service Manual (aka FSM).
Wheelin98TJ is offline
post #4 of 10 Old 08-04-2020, 01:15 PM
jkp
Owners manual at Jeep.com is a free download.
Yes, front specs 80W-90, I just put 75W-140 in both for simplicity.
'92 Islander
'06 Rubicon
jkp is offline
post #5 of 10 Old 08-05-2020, 06:07 PM
JeepingNet
I think you'll find a lot of people use 85W-140
Colin Jennings
Trail - 2005 Jeep LJ Rubicon
Daily - 2007 Jeep Grand Cherokee Limited 5.7L
JeepingNet is offline
post #6 of 10 Old 08-05-2020, 07:07 PM Thread Starter
Ijeepalone
Very good, thanks gents. When I picked up the Mopar diff fluid today (75W140 for both pumpkins), the dealer parts dude also brought out some friction modifier. I told him of multiple sources that said it was not required. Thoughts?
post #7 of 10 Old 08-05-2020, 08:26 PM
2jhanna
Most "top shelf" gl5 gear lubes today have the friction modifier already built in. Even if not needed, it doesn't hurt, but good you didn't pay extra for it, on top of the probably high price for the dealer fluid.
jhanna
denton county, tx
2jhanna is offline
post #8 of 10 Old 08-05-2020, 09:51 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Neither the Rubicon lockers nor its rear limited slip differential needs the friction modifier. It's of no use in the Rubi axles.
Surprising to some is if you run a standard conventional (non-synthetic) GL-5 gear lube your gears will run significantly cooler than if with a synthetic gear. True. Many axle builder companies like Currie and Dyan require conventional GL-5 gear lubes to keep their warranties in effect due synthetic gear lubes making the gears run hotter.
Revolution Gear specifies a conventional gear lube during the break-in process.
This from https://www.revolutiongear.com/ring_...reak_procedure
"Recommended gear oil is an 80W-90 or 85W-140, Non-Synthetic, GL5 grade or Higher, Name Brand Oil.
JeepingNet and Ironhead like this.
Jerry Bransford is offline
post #9 of 10 Old 08-06-2020, 04:55 AM Thread Starter
Ijeepalone
Awesome, thank you all!
post #10 of 10 Old 08-07-2020, 07:26 PM
joe_jeep
i have been running 85w140 conventional since the re-gear.
no problems. changed twice pretty quickly after the re-gear.
Jerry Bransford likes this.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
