is this correct? (speedo gear for 33s w/ 4.88 gears) - JeepForum.com
post #1 of 12 Old 05-21-2008, 05:43 AM Thread Starter
zband
zband's Avatar
4.88 gears and 33's - 41 tooth speedo gear?
Most charts dont go that high and I found a chart on an outdated website. So I wasn't sure about the speedogear size.
zband is offline
post #2 of 12 Old 05-21-2008, 06:43 AM
Zlake
Guest
Yeah I looked at two charts and they both say 41
Zlake is offline
post #3 of 12 Old 05-21-2008, 08:32 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
TheBoogieman is offline
post #4 of 12 Old 05-21-2008, 08:40 AM
robplumm
How much difference does one tooth make? They don't carry 39 tooth, but they do have 38.
robplumm is offline
post #5 of 12 Old 05-21-2008, 08:58 AM
Zachs
Then order it from somewhere else. There's tons of places on the net that offer speedo gears.
This is where I got mine:
http://www.transmissioncenter.org/sp...e_and_jeep.htm
2000 Sahara TJ
1997 Limited ZJ
Zachs is offline
post #6 of 12 Old 05-21-2008, 09:03 AM
schebs05tj
Hijack/ I'm getting ready to install axles with 4.88s and I am running 33" tires. How does this combo drive.
05 TJ Rocky Mountain Edition, Black on Black
schebs05tj is offline
post #7 of 12 Old 05-21-2008, 09:10 AM
airframer
airframer's Avatar
same here.......
Everything in moderation
airframer is offline
post #8 of 12 Old 05-27-2008, 09:59 AM Thread Starter
zband
zband's Avatar
Originally Posted by airframer View Post
same here.......
This came from a thread I started on deciding what gears to go with, there is some good information in it. thread
To summarize for 33's : 4speed auto (42rle ) go with 4.88's/ 5 or 6 speed manual go with 4.56.
I put some information about the 42rle transmission on that blog thing here, and will post my impressions (you know I love my MPG's) soon.
zband is offline
post #9 of 12 Old 05-27-2008, 10:07 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your RPMs will be pretty close to 3000 RPMs at 70 mph with your manual transmission, which is pretty high. Do you intend to stay with 33" tires? If so, I'd go with 4.56 instead of 4.88. But if 35" tires are in your future, the 4.88 gears will be ideal.
Jerry Bransford is offline
post #10 of 12 Old 05-30-2008, 02:25 PM Thread Starter
zband
zband's Avatar
OK - I called the place that Zachs suggested and did their "speedo" calculator.
the link to their calculator is here. I have goodyear mtr's which measure about 32.5" could some decode the other options ie, is it a "driven " gear or "drive gear"? Drive teeth (the guy said change to 13 ??)
I got a value of 39 not 41! Currently, I have (from Quadratec's chart) a 31 tooth gear and its ok for accuracy (+/- 3 mph at 65mph) but his chart says go with 30 tooth.
zband is offline
post #11 of 12 Old 05-30-2008, 02:30 PM
Jerry Bransford
Administrator
39 is incorrect for 4.88 gears and 33" tires, that's the gear tooth count that is accurate for 35" tires and 4.88 gearing. I'm running a 39 tooth gear, 35" tires, and 4.88 gearing and my speedometer is dead-nuts on and veriffied with my GPS. A 41 tooth gear is what you want. A good accurate speedo gear chart that is well known for its accuracy is at http://www.4x4xplor.com/images/speedo/speedochart00.gif
post #12 of 12 Old 05-30-2008, 02:45 PM
CHRRRIS
Guest
Jerry, where'd you get a 39 tooth? I could use one, now.
CHRRRIS is offline
Correct Speedo Gear # Dylan11 TJ Wrangler Technical Forum 5 07-30-2009 11:46 AM
correct speedo gear 4xjeep TJ Wrangler Technical Forum 2 09-29-2008 09:16 PM
correct speedo gear for 33" tires? duality TJ Wrangler Technical Forum 4 01-22-2008 02:17 PM
what speedo gear do i need to make it correct crxman91 TJ Wrangler Technical Forum 1 09-29-2005 05:31 PM
Correct speedo gear? rtroha YJ Wrangler Technical Forum 8 02-17-2003 10:27 AM
