Coolant Problem - JeepForum.com
post #1 of 10 Old 05-25-2010, 05:41 PM Thread Starter
69MelMan
Coolant Problem
Replaced the Heater and radiators hoses, radiator, thermostat, thermostat housing and serpentine belt on a 2001 TJ with the 2.5l. Problem is no heat, no hot coolant flowing to the heater hoses. Flushed it again and took it for a drive. Couldn't get it over 150 degrees. Thermostat is rated 195 degrees per OEM. Frustrated, replaced the thermostat to no avail. Belt is routed correctly and tension is correct as well. Is a faulty water pump the most likely culprit? Argh.
69MelMan is offline
post #2 of 10 Old 05-25-2010, 07:19 PM
mightydog78
mightydog78's Avatar
did you put the theromstat in correctly to make sure it wasnt sticking?
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #3 of 10 Old 05-25-2010, 07:56 PM
wtroger
Sounds like the impeller on the water pump is gone.
wtroger is offline
post #4 of 10 Old 05-25-2010, 08:12 PM
Sahara01
Are you filling the system correctly? Filling up, starting the vehicle and running till the thermostat opens and then topping it off ? Do you have the heat on to make sure the fluid circulates and fills the heater core ? If not that could be causing your problem.
Shortbus Offroad Team #242
sponsored by
, GOODYEAR TIRES,
, Solid Axle Industries, Genright,
Sahara01 is offline
post #5 of 10 Old 05-25-2010, 08:51 PM
asknight
asknight's Avatar
Turning the blower motor on doesn't have anything to do with coolant flow through the heater core.
Sounds like the water pump impeller is corroded away or there is an air pocket in a water jacket.
asknight is offline
post #6 of 10 Old 05-25-2010, 08:52 PM
bruteboy
you post that you can't get it to go over 150degrees which means it is not overheating.
correct?
bruteboy is offline
post #7 of 10 Old 05-30-2010, 05:40 PM Thread Starter
69MelMan
Correct, not overheating. Have to pickup a code reader, it throws one due to sensor not getting a reading after 12 seconds. One other suggestion I will follow prior to replacing the pump and fan clutch was suggested on wranglerforum.com. The thermostat should have a 1/8 to 3/16 bleed hole positioned at the top when you install it so as to avoid air being allowed into the system during refill. I will post what corrects the problem for others with similar issues. Many thanks for all responses.
69MelMan is offline
post #8 of 10 Old 05-30-2010, 05:49 PM
blubaru2002
Correct me if I am wrong, but the whole in the top of the thermostat is there to let a possible air bubble travel through the system. It is designed this way so that air does not get stuck in any one point in the coolant system.
If you had air in your coolant system, you would overheat (ask me how I know.)
Sounds like your waterpump is shot, or the thermostat is stuck open or backwards.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #9 of 10 Old 05-30-2010, 08:45 PM
Dryseals
1980 CJ7
Geeze guys come on. If he's not getting to temperature, it's not going to be a lack of flow. It's going to be too much flow. My thoughts are the thermostat stuck wide open.
The hole in the thermostat is to allow flow, even a tiny little bit, this way there's always an exchange of fluid happening around the thermostat. Without the hole, no flow, and it would take longer for heated coolant to reach the thermostat.
Do a quick test on the thermostat, drop it in a pan of water and watch it open and using a thermometer see what temperature it opens at. I have seen a few in my day go wide open very early. Almost snap open way below temperature.
Dryseals is offline
post #10 of 10 Old 05-30-2010, 09:24 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
That's how I understand it...
Gone but not forgotten.
Knuckelhead is offline
Coolant/possible head problem. Need help! MalevolentChewy TJ Wrangler Technical Forum 9 05-17-2010 01:26 PM
If Anyone Has had This Problem, Please Help! Coolant temp./Gauge problem tjbrotha TJ Wrangler Technical Forum 2 06-03-2009 12:14 PM
possible coolant problem(pics) IBreakStuff TJ Wrangler Technical Forum 10 01-05-2009 10:20 PM
Coolant/Radiator problem mcg TJ Wrangler Technical Forum 17 08-21-2006 11:38 AM
Coolant Explosion Problem onebigtj TJ Wrangler Technical Forum 6 10-26-2005 11:59 AM
