constant whine coming from power steering? - Page 2 - JeepForum.com
post #16 of 23 Old 08-09-2010, 06:43 AM
anymanusa
Redline syn. ps fluid reduced my noise significantly.
anymanusa is offline
post #17 of 23 Old 08-09-2010, 11:14 PM Thread Starter
Utfan010
thanks man. ill be sure to do it.
when in doubt, press the skinny pedal!
Utfan010 is offline
post #18 of 23 Old 08-25-2010, 09:34 AM
urstolendesire
Hey guys, i'm having the same issue. but my fluid level has never been to the low mark, and no leaks?? is it normally the actual pump that whines or is it the pulley? I dont know why this thing has just started whining but its getting worse...
urstolendesire is offline
post #19 of 23 Old 08-25-2010, 09:40 AM
KEH1997
KEH1997's Avatar
It's often the actual pump. Chances are you'll need to replace it, if it's getting worse as you say. Not too hard to do yourself, if you're up for it.
KEH1997 is offline
post #20 of 23 Old 08-25-2010, 09:42 AM
urstolendesire
yeah it just looks like a couple bolts & the pressure/return lines... would it be a good idea to change the lines as well? is there some type of filter i should look at?
post #21 of 23 Old 08-25-2010, 09:44 AM
KEH1997
KEH1997's Avatar
It's not a bad idea to change the lines while you're at it, but I didn't do that when I replaced mine and it's been fine. There's no filter to mess with. I would recommend you get a new pump that includes the reservoir, instead of getting just the pump by itself.
KEH1997 is offline
post #22 of 23 Old 08-25-2010, 09:51 AM
urstolendesire
arright cool. thanks alot... thats just another $100 ive gotta spend on the thing. after everythings back together, just do that bleed thing by turning the wheels back and forth for a while?
post #23 of 23 Old 08-25-2010, 09:55 AM
KEH1997
KEH1997's Avatar
Yeah, more or less. Jack it up to get the wheels off the floor, then turn it all the way left and all the way right (but not hitting the steering stops) until bubbles stop coming out of the PS reservoir. Then start the engine and continue turning it left and right, as before. After about 30 or 40 turns you should be ok. Watch the pump for leaks for the next several weeks.
KEH1997 is offline
Leaking , power steering , rpm , whine , whining noise
Wookie roar coming from my power steering Pallando TJ Wrangler Technical Forum 3 01-21-2010 08:40 PM
power steering whine provinT13 YJ Wrangler Technical Forum 4 11-21-2008 09:02 PM
constant POWER wick913 TJ Wrangler Technical Forum 5 09-07-2008 01:43 AM
Loud constant whine (no not my girlfriend) axle? - help zband TJ Wrangler Technical Forum 10 09-03-2008 02:39 PM
Loud Whine coming from under the hood carr51 TJ Wrangler Technical Forum 6 01-21-2007 11:49 AM
