constant whine coming from power steering? - JeepForum.com
post #1 of 23 Old 08-05-2010, 12:16 PM Thread Starter
Utfan010
okay so i have a extremely loud whine coming from the engine, the whine is always there as long as the engine is on. when the RPMs rise the whine gets extremely louder. i do have my power steering gear box seal leaking, could this be the cause of the whine like air in the lines? because the sound is coming from some where around the power steering pump. does a bad steering pump whine like that?
when in doubt, press the skinny pedal!
Utfan010 is offline
post #2 of 23 Old 08-05-2010, 12:24 PM
mdm
Farm Wheeler
Yes.
Have you checked the fluid level?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 23 Old 08-05-2010, 12:25 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Yes
GOLENJEEPTJ is offline
post #4 of 23 Old 08-05-2010, 12:27 PM
KEH1997
KEH1997's Avatar
You could try bleeding it, but it may have done permanent damage by now. I'd bleed it really well, check the fluid, and if it's still there, plan to replace it. It's not a hard job... I just did it this weekend, actually.
KEH1997 is offline
post #5 of 23 Old 08-05-2010, 12:44 PM Thread Starter
Utfan010
yeah fluid levels are fine, i have the lucas oil power steering stop leak in it right now. not doin a whole lot of good. but i was plannin on changin the power steering pump and gear box soon anyways.
Utfan010 is offline
post #6 of 23 Old 08-05-2010, 12:47 PM
Gonewhln
Gonewhln's Avatar
sounds like a pulley take it off clean it out and regrease it then reinstall it cheaper than buying a new one....
Gonewhln is offline
post #7 of 23 Old 08-06-2010, 12:44 AM Thread Starter
Utfan010
i just put a brand new power steering pulley on it this weekend and it didnt help any. greased it up and everything.
Utfan010 is offline
post #8 of 23 Old 08-06-2010, 04:03 AM
ElementX
ElementX's Avatar
You need to bleed the power steering system. If you're leaking, then you will have air in your system. It's just matter of how much air. If you're hearing a loud whine from the pump, it either has a lot of air running through it, or its damaged....from lots of air running through it.
'98 TJ Sport
ElementX is offline
post #9 of 23 Old 08-07-2010, 08:32 PM Thread Starter
Utfan010
alright im gonna bleed the system tonight then. how exactly is it done. ive never had to bleed any lines before so any advice
Utfan010 is offline
post #10 of 23 Old 08-08-2010, 07:01 AM
KEH1997
KEH1997's Avatar
Jack the front end of the Jeep up to make it easier to turn the wheels. Turn them all the way to the left, then all the way to the right, but don't hit the steering stops. Do this for several minutes, or until you don't see any more bubbles coming out of the power steering pump reservoir. Then, start the engine and let it idle while you continue to turn the wheel all the way left and all the way right (again, don't let it hit the steering stops). Keep doing this for, literally, 30 or 40 times. After that, it should be sufficiently bled.
KEH1997 is offline
post #11 of 23 Old 08-08-2010, 03:52 PM
wushaw
Rockin jeep
wushaw's Avatar
Have you let the resivour run real low?
wushaw is offline
post #12 of 23 Old 08-08-2010, 07:55 PM Thread Starter
Utfan010
yeah last night i did exactly that. but sadly it did nothing to help the noise go away. i would just about say the pump has gone bad...hopefully im wrong.
Utfan010 is offline
post #13 of 23 Old 08-08-2010, 08:43 PM
wushaw
Rockin jeep
wushaw's Avatar
Since you let it get so low to where it is whining I would have to say yes you probably burned up the vanes. But try to bleed it and give it a whirl...it's only gonna cost ya a little fluid.
wushaw is offline
post #14 of 23 Old 08-08-2010, 09:14 PM Thread Starter
Utfan010
the power steering fluid level never gets low even when i tried bleeding the system it just kept rising up in the reservoir. it never really went down to much.
Utfan010 is offline
post #15 of 23 Old 08-09-2010, 06:33 AM
KEH1997
KEH1997's Avatar
It shouldn't drop unless you have a leak somewhere. If the whine is still there after you bled the system, it's probably time to replace the pump.
Just a word of advice: Go ahead and get the more expensive pump that comes with a new reservoir. They sell the pump itself (w/o reservoir), but you're sure to have leaks if you go that route.
KEH1997 is offline
Leaking , power steering , rpm , whine , whining noise
Wookie roar coming from my power steering Pallando TJ Wrangler Technical Forum 3 01-21-2010 08:40 PM
power steering whine provinT13 YJ Wrangler Technical Forum 4 11-21-2008 09:02 PM
constant POWER wick913 TJ Wrangler Technical Forum 5 09-07-2008 01:43 AM
Loud constant whine (no not my girlfriend) axle? - help zband TJ Wrangler Technical Forum 10 09-03-2008 02:39 PM
Loud Whine coming from under the hood carr51 TJ Wrangler Technical Forum 6 01-21-2007 11:49 AM
