JeepForum.com (https://www.jeepforum.com/forum/)
-   TJ Wrangler Technical Forum (https://www.jeepforum.com/forum/f9/)
-   -   clutch/transmission issue (https://www.jeepforum.com/forum/f9/clutch-transmission-issue-4403801/)
scottdp 07-10-2020 01:05 PM
All,
I have a 1999 jeep wrangler sport. (my son's car) He blew a wheel cylinder so I did a complete rear brake job on both sides. That went well and was successful, however, when test driving first time had some grinding between 3rd and 4th. Then later a little between 1& 2. I brought it home and opened the master cylinder. Plenty of fluid; however, when I took it back out it was worst as if it was never being released from gear. Background...I put in a new clutch around December. All went well but was my first time. The master cylinder and slave are new also. I am concerned that the throw out bearing may be shot or do you think I should try bleeding the master/slave cylinder. I have not had time to check anything yet but thought I would ask your opinions to direct my trouble shooting. Thanks for any guidance you can provide.
Scott
BlueFl.Wrangler 07-10-2020 01:47 PM
Do I get the impression that when you replaced the clutch that you re-used the old release bearing??
Try using red line fluid-- it makes a HUGE difference, it could very well fix those issues.
scottdp 07-10-2020 02:15 PM
I put in a luk clutch kit and a new throw out bearing by National. I use the Redline fluid.
bobjp 07-11-2020 05:45 AM
It is the master or slave. I would start with the slave.
The time now is 11:48 AM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
