Cleaning up 99 TJ Side seps - JeepForum.com
post #1 of 3 Old 05-09-2020, 02:14 PM Thread Starter
mmitsch
I bought used side steps to replace my original ones and would like to clean them up & paint them. I can’t seem to take the nuts off (bolt just spins),
Is there some trick to this?
See attached photos.
Thanks!
Mike
502139DA-C7FB-4A3D-8503-4F26963A1384_1589055216967.jpg   E78B78CF-3D90-47E7-A221-0176D1D7A96F_1589055234276.jpg
mmitsch is offline
post #2 of 3 Old 05-10-2020, 02:29 AM
Jonny Jeep
Jonny Jeep's Avatar
The heads of the bolts, being moulded into the plastic, don't have much to stop them from turning compared to the torque the rust can apply from the nut. Even if you could cut the nuts off somehow, you'd still have the problem of nothing holding the head when you try to put them back together. When I had those steps years ago I damaged one of them, and the bolt heads were ripped out of the steps. The only way to secure the step was to drill the holes through to the top and put coach bolts through the step. Best just cleaning and painting as they are.
Jonny Jeep is offline
post #3 of 3 Old 05-23-2020, 01:10 PM
WallyDog1
WallyDog1's Avatar
No guarantees but try soaking them with PB Blaster for several days. It's pretty amazing stuff if left to sit. The question would be if the plastic will hold when you try to unscrew. For tough nut removal before the plastic gave up it's grasp the quick zip of an impact gun might do it after the soaking. I think I would agree to clean them and paint them without trying to take them apart. You can't see the bottom anyway. If you can your up side down
From the Smoky Mountains of Western North Carolina
WallyDog1 is offline
