cleaning soft windows with pledge??? - JeepForum.com
post #1 of 18 Old 11-04-2011, 08:43 AM Thread Starter
Temple
Could of swore i read that somewhere on here. Dont want to use windex, afraid of dis-coloring. Any tips would be great, thanks
Temple is offline
post #2 of 18 Old 11-04-2011, 08:50 AM
JeffBowser
JeffBowser's Avatar
Could HAVE sworn, not"could OF swore".....
I wouldn't use Pledge on my furniture, let alone jeep window (it leaves a wax residue). I use soap and water,period. Once in awhile, I'll clean the inside with a spray cleaner made for this type of window. Right now I have a can of this: http://www.mypilotstore.com/MyPilotStore/sep/1150
JeffBowser is offline
post #3 of 18 Old 11-04-2011, 08:52 AM
quadna71
quadna71's Avatar
or....Pledge works for a quick fix. It'll lighten back up in a few weeks but usually will make them pretty clear for a while. Just make sure you combine JeffBowser's advice too and use a light soap/water mix to clean them first so you aren't just buffing the dirt into the plastic.
Current - 13 JKU, 01 TJ
Gone - 03 TJ, 01 XJ, 00 TJ, 93 XJ, 87 XJ, 87 XJ, 53 CJ-3B
quadna71 is offline
post #4 of 18 Old 11-04-2011, 09:44 AM
Bordr329
Clean with soapy water, spray on pledge, lighly buff to white glazed look, grab new cloth, buff, enjoy the lemony freshness
Bordr329 is offline
post #5 of 18 Old 11-04-2011, 10:12 AM
danielbuck
danielbuck's Avatar
1946 CJ2
I used pledge on a long trip across the US and back, it clears up the windows pretty good, but as mentioned, it doesn't really seem to last very long (more than a week or two for sure, but not a long time). I rinsed mine with warm water and a clean towel to get all the grit off, then once it was dry I used pledge and a small cloth, it seemed to work real good, and does make it fairly easy to quickly whipe off any dust or dirt that gets on there afterwords... for a little while anyway. Pledge is pretty cheap though, and you can get it just about anywhere, so that's nice.
danielbuck is offline
post #6 of 18 Old 11-04-2011, 10:29 AM
FelonyTJ
Best Top vinyl window cleaner?
FelonyTJ is offline
post #7 of 18 Old 11-04-2011, 10:48 AM
hustler905
hustler905's Avatar
There are different Pledges out there.
I would not use yellow, but orange Pledge leaves a lot less wax residue and has a citrus based cleaner in it. I have used that a few times before storing my windows and it works great.
hustler905 is offline
post #8 of 18 Old 11-04-2011, 11:02 AM
PurpleTJ
PurpleTJ's Avatar
McSomethin's "Plastix". Autozone has it. I found out about it here on JF somewhere, and it works great. I just used it like a week ago. No discoloring, and the windows are now much clearer. I have pics in my build but they don't do much justice.
Purple Jeep Club member #8
PurpleTJ is offline
post #9 of 18 Old 11-04-2011, 11:02 AM
Dogman
Dogman's Avatar
I use it every once in a while after cleaning my windows up really good with soap and water. Make sure they're dry then hit them with the Pledge (the orange is my favorite).
John 3:17
Dogman is offline
post #10 of 18 Old 11-04-2011, 11:08 AM
Dogman
Dogman's Avatar
It's Meguiar's Plastx. I got some of that and I like the Pledge better. But, to each his own
John 3:17
Dogman is offline
post #11 of 18 Old 11-04-2011, 12:32 PM
Timido
We use to use Pledge or Honda Clean in the spray cans on Motorcycle fairings and windshield Worked great
Timido is offline
post #12 of 18 Old 11-08-2011, 06:17 AM Thread Starter
Temple
Thanks everybody
Temple is offline
post #13 of 18 Old 11-08-2011, 06:46 AM
vjw0307
I used a headlight cleaner on my soft windows...was AMAZED at how well it worked...I can actually see out of them now! Does a great job of "de-hazing" them and removes minor scratches!
vjw0307 is offline
post #14 of 18 Old 11-08-2011, 06:52 AM
RandyTJ
Same here..........also wipe down your dash and door panels with the pledge rag...........smell the freshness!
White 2005 LJ, Rubicon, Rubicon Express 3.5 SuperFlex, Goodyear 315/75/16 MTR's, Pro Comp 97 16x8 wheels, UCF Tummy Tuck, 1" Prothane BL, 1" JKS MML,Tereflex Disco's, 10,000 lb. winch. CB Radio, Fire Extinguister, Synthetic Fluids, Driving Lights....
1999 XJ 6.5 Lift, Rusty's Long Arm, Four Link Rear Suspension, ARB Lockers Front and Rear, Alloy Axles....
RandyTJ is offline
post #15 of 18 Old 11-08-2011, 06:55 AM
deadwalkinsammy
What about zep window cleaner for vinyl windows, I would imagine that would work good...
deadwalkinsammy is offline
Cleaning Soft Top Windows SugarBear TJ Wrangler Technical Forum 4 12-27-2009 03:58 PM
Cleaning soft top windows 7elmdale JK Wrangler Technical Forum 8 03-13-2009 07:53 PM
Cleaning windows on a soft top? supercub43 TJ Wrangler Technical Forum 22 01-17-2007 01:24 AM
Pledge on plastic windows?? / washing the soft-top 94523 TJ Wrangler Technical Forum 9 01-17-2006 01:03 AM
Cleaning soft windows? BIGNUTT TJ Wrangler Technical Forum 10 06-08-2005 06:03 PM
