JeepForum.com (https://www.jeepforum.com/forum/)
-   TJ Wrangler Technical Forum (https://www.jeepforum.com/forum/f9/)
-   -   cleaning soft windows with pledge??? (https://www.jeepforum.com/forum/f9/cleaning-soft-windows-pledge-1285265/)
Temple 11-04-2011 08:43 AM
Could of swore i read that somewhere on here. Dont want to use windex, afraid of dis-coloring. Any tips would be great, thanks
JeffBowser 11-04-2011 08:50 AM
Could HAVE sworn, not"could OF swore"..... :)
I wouldn't use Pledge on my furniture, let alone jeep window (it leaves a wax residue). I use soap and water,period. Once in awhile, I'll clean the inside with a spray cleaner made for this type of window. Right now I have a can of this: http://www.mypilotstore.com/MyPilotStore/sep/1150
quadna71 11-04-2011 08:52 AM
or....Pledge works for a quick fix. It'll lighten back up in a few weeks but usually will make them pretty clear for a while. Just make sure you combine JeffBowser's advice too and use a light soap/water mix to clean them first so you aren't just buffing the dirt into the plastic.
Bordr329 11-04-2011 09:44 AM
Clean with soapy water, spray on pledge, lighly buff to white glazed look, grab new cloth, buff, enjoy the lemony freshness
danielbuck 11-04-2011 10:12 AM
I used pledge on a long trip across the US and back, it clears up the windows pretty good, but as mentioned, it doesn't really seem to last very long (more than a week or two for sure, but not a long time). I rinsed mine with warm water and a clean towel to get all the grit off, then once it was dry I used pledge and a small cloth, it seemed to work real good, and does make it fairly easy to quickly whipe off any dust or dirt that gets on there afterwords... for a little while anyway. Pledge is pretty cheap though, and you can get it just about anywhere, so that's nice.
FelonyTJ 11-04-2011 10:29 AM
Best Top vinyl window cleaner?
hustler905 11-04-2011 10:48 AM
There are different Pledges out there.
I would not use yellow, but orange Pledge leaves a lot less wax residue and has a citrus based cleaner in it. I have used that a few times before storing my windows and it works great.
PurpleTJ 11-04-2011 11:02 AM
McSomethin's "Plastix". Autozone has it. I found out about it here on JF somewhere, and it works great. I just used it like a week ago. No discoloring, and the windows are now much clearer. I have pics in my build but they don't do much justice.
Dogman 11-04-2011 11:02 AM
I use it every once in a while after cleaning my windows up really good with soap and water. Make sure they're dry then hit them with the Pledge (the orange is my favorite).
Dogman 11-04-2011 11:08 AM
It's Meguiar's Plastx. I got some of that and I like the Pledge better. But, to each his own :D
Timido 11-04-2011 12:32 PM
We use to use Pledge or Honda Clean in the spray cans on Motorcycle fairings and windshield Worked great
Temple 11-08-2011 06:17 AM
Thanks everybody
vjw0307 11-08-2011 06:46 AM
I used a headlight cleaner on my soft windows...was AMAZED at how well it worked...I can actually see out of them now! Does a great job of "de-hazing" them and removes minor scratches!
RandyTJ 11-08-2011 06:52 AM
Same here..........also wipe down your dash and door panels with the pledge rag...........smell the freshness!
deadwalkinsammy 11-08-2011 06:55 AM
What about zep window cleaner for vinyl windows, I would imagine that would work good...
The time now is 07:38 AM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
