clayton long arm vs Rubicon Express long arm - JeepForum.com
post #1 of 6 Old 01-09-2008, 07:19 PM Thread Starter
Squeeky
Guest
can any body give me comparative notes and pros and cons of both kits (5.5)..they both look very similar...
i know that the clayton kit comes with a lifetime warranty against bending and breakage...its also about $300 cheaper...
Squeeky is offline
post #2 of 6 Old 01-09-2008, 07:37 PM
kd4yor
there is no comparison. Clayton all the way
I don't have enough lift to "stuff a tire"
kd4yor is offline
post #3 of 6 Old 01-09-2008, 07:49 PM
Scotch740
Scotch740's Avatar
What was your question again
However
Originally Posted by Clayton's website
This suspension product requires welding it onto and/or modifications to your vehicle's frame. For your safety as well and to ensure the system's durability and optimum performance it is recommended that installation is performed by an experienced and qualified welder or 4x4 shop. Installation procedures should be followed closely.
If you are comfortable with welding go for it. Other wise a shop will probalby charge significantly more than $300.
Scotch740 is offline
post #4 of 6 Old 01-09-2008, 07:53 PM Thread Starter
Squeeky
Guest
i have a buddy who is willing to do the welding..hes a certified welder
Squeeky is offline
post #5 of 6 Old 01-09-2008, 08:12 PM
JerryC
I've had both. The basic kits both use front radius arm designs but Clayton's basic kit uses a 4 link rear.
I got good service out of my RE until I bent a rear LCA. It didn't put the Jeep down, but that was enough for me.
I installed the Clayton rear 4 link RE conversion. Goodbye rear trackbar and RE rear arms. That was better.
Then I took the rig to Clayton's shop and had him install a 4" rear stretch and replaced all the remaining RE components with Clayton components. That's better yet.
Now, if we can only get him to work out a nice 3 link front design........
Seriously, if yoiu have a buddy who can weld, don't even think twice. Get the Clayton kit.
JerryC is offline
post #6 of 6 Old 01-09-2008, 09:16 PM Thread Starter
Squeeky
Guest
ive been thinking...
if i wanted to swap my axles to built d44's later on id have to order new weld on brackets from clayton right?
Squeeky is offline
Rubicon Express/Mopar 4.5" Long Arm vs Teraflex 4" Long arm, which one is best? SaharaBlackNo1 JK Wrangler Technical Forum 20 04-24-2010 12:39 PM
Rubicon Express Long Arm bguerrero TJ Wrangler Technical Forum 12 11-22-2009 02:48 AM
Full-Traction Long Arm or Rubicon Express Long Arm GopherGuy TJ Wrangler Technical Forum 14 08-21-2009 06:26 PM
Rubicon Express long arm lift Q's TJ on the Rocks TJ Wrangler Technical Forum 9 05-10-2006 11:18 AM
Rubicon Express Long Arm 4.5 kit NOT the 5.5 kit??? jeepgirl6 TJ Wrangler Technical Forum 40 01-19-2006 08:48 PM
