Chsnge head gasket before it starts leaking/blows? - JeepForum.com
post #1 of 10 Old 11-07-2011, 04:04 PM Thread Starter
Barcus
Barcus's Avatar
Just thinking proactively...i have 117,000+ on the motor and was thinking of changing it before i need to. Question is, should i still get the head resurfaced if im not experiencing any problems?
EDIT: the motor runs fine, does not overheat nor do i have oil/coolant mixing together.
98 TJ Currie arms-RC 2.5 coils-RC 2.0 shocks-1.25 BL-TF rear track bar-custom bumpstops-mud-scratches-gas.
Barcus is offline
post #2 of 10 Old 11-07-2011, 04:11 PM
Meh
Not sure if I would change the head gasket (especially on a 4.0) as just maintenance. If you have some upgrades planned (port/polish, etc then maybe) otherwise the head gasket is not a typical problem on 4.0s unless you have been running it hot or have a million miles. There is a lot of other regular maintenance items and/or mods you could make with your money instead of replacing a head gasket that doesn't have a problem.
Meh is offline
post #3 of 10 Old 11-07-2011, 04:32 PM
MikeyJ
Don't fix what's not broken.
MikeyJ is offline
post #4 of 10 Old 11-07-2011, 05:05 PM
heapashifter
I wouldn't do it now.
heapashifter is offline
post #5 of 10 Old 11-07-2011, 05:17 PM
relgnarw
relgnarw's Avatar
This
"I had wobster at Wed Wobster" - Austin age 5
My onboard air build.
relgnarw is offline
post #6 of 10 Old 11-07-2011, 06:11 PM Thread Starter
Barcus
Barcus's Avatar
Yeah y'all are right I just get paranoid about maintenance sometimes with it being a DD.
Barcus is offline
post #7 of 10 Old 11-08-2011, 10:39 AM
byoungblood
I've driven a couple of vehicles close to, or over 200,000 miles and never had issues with head gaskets on either. My TJ currently has 130,000 miles on it with no engine issues. It is one of those things that often outlasts everything else on a vehicle.
byoungblood is offline
post #8 of 10 Old 11-08-2011, 10:45 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
My old Jeep has over 230,000 miles on it now and never had the head gasket replaced.
TheBoogieman is offline
post #9 of 10 Old 11-08-2011, 10:47 AM
limeking
Why mess with something that is not broke? Seems like you could cause yourself more headaches doing this.
If there wasn't stuff that sucked, how would we know what was cool? Beavis and Butthead
Jeremy : )
2004 Lime Rubicon, NV3550, JKS arms, and trackbars, UCF tummy tuck, LoPro and engine skid, 3 in tera springs 33 KM2s
1994 Red Wrangler, 2.5 in lift, 31 in no names, 4.0 ax15 30/35
limeking is offline
post #10 of 10 Old 11-08-2011, 10:51 AM
AntiPrius
I wouldn't even consider it. Especially with my luck, it'd leak if I replaced it for no reason, then I'd be sitting there wishing I never touched it.
I know because that is exactly what happened to my rear main seal. I had to take the oil pan off for another reason and decided to change out the RMS while I was in there. It didn't leak before, now it does just slightly. Not enough to worry about, just an occasional tiny drop, but it didn't leak at all before.
I've learned my lesson.
Well I did replaced the whole cooling system even though just the radiator was leaking, and everything went fine, but...
AntiPrius is offline
Blown CYLINDER HEAD / HEAD GASKET JB73 TJ Wrangler Technical Forum 19 01-16-2011 01:38 AM
Blown Head gasket should i just buy a new head? BrycenWebb1 TJ Wrangler Technical Forum 2 07-01-2010 12:06 AM
Ignition fuse blows out when jeep starts Torres8956 YJ Wrangler Technical Forum 1 12-04-2008 12:20 PM
Questions on possible leaking head gasket farmer-dave TJ Wrangler Technical Forum 4 05-08-2005 06:56 AM
head gasket, head swap, 4.0 or stroker sailor77 YJ Wrangler Technical Forum 3 02-25-2005 04:06 PM
