Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 123 - JeepForum.com
 4Likes
post #1831 of 1833 Old 02-27-2018, 09:55 AM
biffgnar
biffgnar's Avatar
Originally Posted by baw51473 View Post
I have not switched the Crown provided sensor with the OEM yet. Will do that first. And the other problem is I made the rookie mistake of not noting the location of the Camshaft sensor before pulling the OPDA. Forgive my ignorance but how do I ensure I am at TDC?
Go to the beginning posts in this thread and there will be detail.
biffgnar is offline
post #1832 of 1833 Old 02-27-2018, 10:21 AM
TJTurbo
When turning the OPDA, like a distributor, there is only a small degree it can be turned either way before it shuts off so I cant be far off. The engine runs pretty smooth, but jostles when I am driving at about 3 grand.
On my '06 there is a groove cut into the harmonic balancer and an alignment "pointer". I think you need a 3/4" socket or boxed end wrench to turn the engine and removal of the serp belt makes it easier. If I remember correctly you turn clockwise facing the front of the engine. Once you get there you will be able to see how far off the housing alignment hole is from the tone wheel alignment hole.
TJTurbo is offline
post #1833 of 1833 Old 02-27-2018, 10:36 AM
Bigbob
Bigbob's Avatar
Look at this video. https://youtu.be/McrtZ6ptSWY
Make sure you have the pulley mark lined up perfect.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
