Check Engine Light question - JeepForum.com
post #1 of 3 Old 04-26-2012, 01:08 PM Thread Starter
01-TJ
Ive been having a check engine light come on lately. Ive reset it a few times and it doesnt take more than 20 mins for it to come back. The code I'm getting is the 'ol P0443 " Evaporative Emission System Purge Control Valve Circut" code. The emission light on my code reader is showing a red light too. Ive also noticed my fuel economy is even worse since this light has been on.
My question is, can this problem be fixed myself? or should this go into a shop for fixing?
01-TJ is offline
post #2 of 3 Old 04-26-2012, 01:08 PM Thread Starter
01-TJ
I should mention, I have a 2001 TJ, 4.0L manual
01-TJ is offline
post #3 of 3 Old 04-26-2012, 08:14 PM
JaikYJ
JaikYJ's Avatar
Hi Rubi4MyMrs posted this in another thread with somebody having the same problem as you. He has been helping me diagnose my CEL woes. Very knowledgable and helpful. Check out the link and see if it helps.
Pretty good explanation there. Here is a simpler take:
Evaporative Emission Control System Purge Control Valve Circuit --- An open or shorted condition detected in the EVAP purge solenoid control circuit. Check the charcoal canister for fuel saturation If the vehicle has been overfueled, then there is a chance that liquid fuel can enter the canister and cause drive problems or emission related problems.
Start by resetting the code & see if it returns, as mentioned in the link you found, it can be a one time thing. If you are not noticing a difference in how the engine runs, you may be OK.
Go here & pick TJ unlimited to get to your '04 & check out the EVAP system, I think it is in the emissions section.
http://www.jeep4x4center.com/knowled...ex.htm#service
87 YJ(sold), 97 TJ(sold), 99 TJ(daily)
03 R1 (fun)68 Mustang Coupe(summer)
67 Fastback(resto)
JaikYJ is offline
I have a question on check engine light dabunnie Wrangler General Discussion 2 09-01-2010 07:53 PM
check engine light question 92renegade YJ Wrangler Technical Forum 17 01-15-2010 07:38 PM
Check engine light question agent_J TJ Wrangler Technical Forum 2 08-17-2008 05:43 PM
Question - Check engine light odie6423 TJ Wrangler Technical Forum 3 04-16-2007 05:10 PM
check engine light question romiin YJ Wrangler Technical Forum 3 10-01-2006 09:09 AM
