Changing oil in dana 30 - JeepForum.com
post #1 of 6 Old 12-14-2010, 06:49 PM Thread Starter
Utfan010
What gear oil is recommended? i have the 4 cylinder with 4.10's? correct me if im wrong. but i need to change the oil soon
when in doubt, press the skinny pedal!
Utfan010 is offline
post #2 of 6 Old 12-14-2010, 06:51 PM
gotmudnj
gotmudnj's Avatar
i put 80-90 in mine gear oil in my d30.....check service manual they might say other wise. i run the 80-90 synthetic blend from valvoline however you spell it.
**** Happens.....
~~GOT MUD CENTRAL NEW JERSEY 4x4 ~~
gotmudnj is offline
post #3 of 6 Old 12-14-2010, 06:58 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
80w90
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 6 Old 12-14-2010, 07:00 PM
superslayer
I'll typically go for walmart supertech 80w90 and the price can't be beat.
superslayer is offline
post #5 of 6 Old 12-14-2010, 07:08 PM
ekim
I look for oil that meets SAE J2630.
ekim is offline
post #6 of 6 Old 12-14-2010, 07:21 PM Thread Starter
Utfan010
thanks guys, need to buy a torque wrench now.
Utfan010 is offline
dana 30 , diff cover , diff fluid , gear oil
Will a dana 35 brum brake backing plate swap onto a dana 44? wzrroc TJ Wrangler Technical Forum 4 03-08-2014 08:24 PM
my dana 35 snaped again can i swap the parts out of a 1990 dana 35 from a cherokee bulickmcj TJ Wrangler Technical Forum 7 04-02-2009 11:42 AM
Changing rear axle seals on Dana 44 '98 Wrangler philipkrug TJ Wrangler Technical Forum 3 09-10-2006 11:29 AM
Build Thread for my Dana 44 and Dana 60 axles... Pics & Questions Inside Big-n-Broke-YJ YJ Wrangler Technical Forum 9 07-11-2006 08:37 AM
QUESTION: front axle(DANA 30) why does mine look like a DANA 35 713JeepTJ TJ Wrangler Technical Forum 5 03-06-2005 08:20 PM
