Changing differential fluid. What method to use?? - Page 2 - JeepForum.com
 15Likes
post #16 of 27 Old 03-15-2018, 10:30 AM
JimSmith
Jerry, I do use one very similar to this for transmission oil and t-case fluids..... But highly suggest a second set of hands to use this one...
https://www.ebay.com/itm/Portable-Ma...cAAOSwWxNYwLeq
'98 Chili Pepper 2.5, AX5, 33x12.5x15, 5.13, D30 Aussie, Super 35
JimSmith is offline
post #17 of 27 Old 03-15-2018, 12:00 PM
RDBills
Originally Posted by Joe_Fordyce View Post
. . . With the lift i have on my TJ i just put a piece of hose onto the end of the clipped nozzle on the bottle, turn it upside-down up above the pumpkin and squeeze the bottle. Works for me, but as always .... YMMV.
That's how I do it when I service the gear oil in my differentials. No special tools needed (although I do use a hose clamp to keep the hose from coming off the bottle). Simply drain and refill with the diff cover in place.
However, for the 500 mile gear oil change after a re-gear which does require removing the diff cover to inspect the newly broken-in gears, I still prefer to have the gear installer do the work so we can inspect the gears together. Besides, removing and replacing the diff cover can be a messy job that I prefer not to do in my own driveway.
gsindela likes this.
Mr. Bills
KG6LMV
'06 Jeep "LJ" Rubicon
RDBills is offline
post #18 of 27 Old 03-15-2018, 12:42 PM
TJR238
TJR238's Avatar
That's what Iím using. Works great when you have someone else to hold the hoses in place. When I use it by myself I usually make a mess.
TJR238 is offline
post #19 of 27 Old 03-16-2018, 10:56 AM
1longcj
I know it looks similar, but I've had good luck with this brand. The pickup tubes are stiffer, and stay attached. Got mine at O'reilys.
Pumps an ounce at a time, and can be disassembled to clean. One hand on the output hose and one on the pump. No problems.
Jerry Bransford and gsindela like this.
Life is short, Play hard.
1longcj is offline
post #20 of 27 Old 03-16-2018, 11:09 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I'll look around for one of those, thanks. My previous pump like that but a different brand is now at the town dump.
Jerry Bransford is offline
post #21 of 27 Old 03-16-2018, 11:21 AM
toximus
I've been using the Plews 55001. They're about $7ea and last just long enough for both diffs. With how messy they end up I'd rather throw it away than pay double and have to store the mess.
Building the right way for 37s.
toximus is offline
post #22 of 27 Old 03-16-2018, 11:37 AM
sduncan
sduncan's Avatar
My electric pump should be here today.. Iíll post back after I do the 500 mile oil change.
sduncan is offline
post #23 of 27 Old 03-16-2018, 12:45 PM
tworley
tworley's Avatar
Thats what I use too, so far it has worked pretty well.
Jerry Bransford likes this.
Colorado Member 307
tworley is offline
post #24 of 27 Old 03-16-2018, 01:14 PM
pcoplin
pcoplin's Avatar
For diffs, I cut the tip and squeeze the bottle. Use a long hose for tcase.
Ive always wanted a metal 5 gallon pump, but would need one with a quart counter. I have a bunch of vehicles and all have different capacities.
Sent from my SM-G930V using Tapatalk
FullStack MotorSports
pcoplin is offline
post #25 of 27 Old 03-16-2018, 01:24 PM Thread Starter
gsindela
OP here: Scheduled the diff gear oil change for this upcoming Wednesday at the installer (Suburban Driveline in Villa Park, IL). I confirmed they remove the diff cover to drain and inspect. Will report back once the job is complete.
RDBills likes this.
gsindela is offline
post #26 of 27 Old 03-16-2018, 01:48 PM
toximus
Best of luck!
toximus is offline
post #27 of 27 Old 03-18-2018, 08:42 AM
danielbuck
danielbuck's Avatar
1946 CJ2
I don't mess with those crappy quart or gallon bottle pumps, more of a headache and a mess than they are worth
With 3 vehicles to maintain it's cheaper to buy a 5 gallon pail of gear oil and a lot cleaner to use a hand pump.
Attachment 3662353
I use one of these for the transmission/transfer case fluid for my CJ, WAY easier than using the hand pumps, especially for thick oil.
danielbuck is offline
diff fluid
