Changed the Speedo gear! - JeepForum.com
post #1 of 6 Old 05-14-2007, 02:13 PM Thread Starter
Axkick
Axkick's Avatar
OK….If you have read any of what I have written in the past, you might know I’m the guy that calls AAA to change a tire….lmao… .I don’t work on cars, trucks or what ever…SO…To start, I would like to thank Stu (http://www.stu-offroad.com/siteindex.asp) and his great web site… Plus all the other post I have read in regards to changing the speedo gear. I got my new Speedo gear on Friday…so Saturday I sat down to put it on…Damn it was easy….I did it in about 5 mins….Took the Jeep for a drive with my Garmin GPS and it is dead on now…I know it was a small task, BUT it was HUGE for me....Almost makes me want to do bigger changes on my own…
Axkick is offline
post #2 of 6 Old 05-14-2007, 02:14 PM
Rocky529
Rocky529's Avatar
Please do this, it will give you a lot of pleasure when you finish the install. Do all your research here first and then go do it.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 6 Old 05-14-2007, 02:15 PM
TJ on the Rocks
Guest
Good job !
A little more confidence and a great site like Stu's really help .
Not to mention the satisfaction of doing the job Yourself and saving some $$$
TJ on the Rocks is offline
post #4 of 6 Old 05-14-2007, 03:06 PM
robncar
robncar's Avatar
We're pullin' for ya! Welcome to the world of wrenching!!! Next up, oil changes and maintenance... good for you! The more you do, the more confidence you'll build.
robncar is offline
post #5 of 6 Old 05-14-2007, 03:27 PM
rljsrubicon
Guest
Research
Rocky529 is correct; only look at other forums as well.. Ron[
QUOTE=Rocky529]Please do this, it will give you a lot of pleasure when you finish the install. Do all your research here first and then go do it.[/QUOTE]
rljsrubicon is offline
post #6 of 6 Old 05-14-2007, 03:38 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Heh, good job and now it's time for you to tackle a suspension lift installation!
Actually, I really wasn't kidding. If you aren't a 60 year old grandmother and know righty-tighty lefty-loosey, you can install a suspension lift on a TJ Wrangler. And if you don't have the tools, you can buy all the basic tools needed and still be money ahead from if you paid a store to install it.
Jerry Bransford is offline
Changed speedo gear-Now Speedo no worky BoatCop TJ Wrangler Technical Forum 7 08-07-2011 04:37 PM
Speedo gear changed today Rule303 TJ Wrangler Technical Forum 9 06-07-2006 05:52 PM
Speedo Gear changed hkiss96 TJ Wrangler Technical Forum 3 11-16-2005 10:58 AM
Speedo gear changed...Performs better? Jeeper X TJ Wrangler Technical Forum 7 07-30-2005 08:51 AM
Changed Speedo Gear 04TJFan TJ Wrangler Technical Forum 9 05-24-2004 10:24 AM
