Cats going bad? - JeepForum.com
 6Likes
  • 4 Post By TheBoogieman
  • 1 Post By jeep63
  • 1 Post By Kolak
post #1 of 14 Old 06-13-2019, 05:13 AM Thread Starter
jeep63
jeep63's Avatar
Cats going bad?
So my son's 06 LJ just threw an engine code for the Downstream Bank 2 O2 sensor. He also says he has to fill up more than usual.
I'm wondering if the cats are bad. Before I lay out 9-bills for a new set of cats, any ideas on troubleshooting ?
I did order 4 new O2 sensors, and now I'm considering ordering a new Cat. Magnaflow makes one that I have read good reviews for. It is pricey, but I hate exhaust work and if it bolts up I'll be pleased.
One benefit is when we bought it, the rear main and transmission cooler lines needed to be replaced, so the bolts are going to come out easily; at least easier than when they did for the rear main & tranny lines.
95 YJ-Sold
YJOTM 05/15,05/18
jeep63 is offline
post #2 of 14 Old 06-13-2019, 05:58 AM
cmecha
Replace pull O2 sensors and see if there is still catalytic material in your 2 pre cats. If there isn't I'd get new cats with O2 sensors
Sent from my ONEPLUS A6013 using Tapatalk
"always upgraded, never replaced."
cmecha is offline
post #3 of 14 Old 06-13-2019, 06:58 AM
ZEN357
Replace the 02 sensors first. I had a vehicle that was drinking gas like a Saturday Night Binder and I replaced the 02 sensors and it went back to normal. I would try that first.
https://www.jegs.com/c/Jeep-Parts-Ac...05704/10002/-1
ZEN357 is offline
post #4 of 14 Old 06-13-2019, 09:04 AM Thread Starter
jeep63
jeep63's Avatar
Thanks for the tips guys.
I have all 4 O2 sensors, the recommended ones (NGK)
We will try that first.
95 YJ-Sold
YJOTM 05/15,05/18
jeep63 is offline
post #5 of 14 Old 06-13-2019, 01:34 PM
Newtons3
Newtons3's Avatar
I would run a backpressure test on the exhaust system and a temp differential check also. If an upstream cat fails, it will easily restrict the lower cat.
Newtons3 is offline
post #6 of 14 Old 06-13-2019, 03:10 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
When my cat went bad it looked like this.
Kolak, Zeep, underscore and 1 others like this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Originally Posted by Jerry Bransford View Post
I'd rather knock myself unconscious, cut a finger off, poke my eye out with a sharp stick or be forced to go back to work than install anything made by Rusty's.
03' Rubicon/Zone 4.25" combo lift/Rancho 9000XL shocks/5.13 gears-35" MTZs/BM brakes
99' XJ on 33s.
TheBoogieman is offline
post #7 of 14 Old 06-13-2019, 03:51 PM Thread Starter
jeep63
jeep63's Avatar
Now that is a 'Bad cat'!!!!
TheBoogieman likes this.
95 YJ-Sold
YJOTM 05/15,05/18
jeep63 is offline
post #8 of 14 Old 06-13-2019, 10:42 PM
bonza
what was the code? I'm guessing either P2096 or P2098
if it's one of those replacing the o2 sensors wont help and I doubt so will replacing the mini cats
I've been getting those codes for years, all I do is clear it with my scan gauge and continue on my way
2005 TJ Light Khaki
bonza is offline
post #9 of 14 Old 06-14-2019, 12:49 AM
Kolak
Vendor
Kolak's Avatar
Check for exhaust leaks upstream. That will also cause a downstream code.
Newtons3 likes this.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #10 of 14 Old 06-14-2019, 03:33 AM
hdsport
Agreed, My TJ threw a Cat Code and I found that there were loose nuts where the exhaust attached to the exhaust manifold.
This causes excess air to enter the exhaust flow and the result is a cat code.
Problem was corrected.
2001 Winnebago Adv 32v MH
2008 Jeep GC , 2005 Willys
US Army Vet, 8th Army,
In God We Trust
hdsport is offline
post #11 of 14 Old 06-14-2019, 04:10 AM Thread Starter
jeep63
jeep63's Avatar
The code was p0421.
95 YJ-Sold
YJOTM 05/15,05/18
jeep63 is offline
post #12 of 14 Old 06-14-2019, 04:13 AM Thread Starter
jeep63
jeep63's Avatar
I’ll also check the bolts.
95 YJ-Sold
YJOTM 05/15,05/18
jeep63 is offline
post #13 of 14 Old 06-14-2019, 07:24 AM
jtec
2014 JK Wrangler
ideally we want to use a scanner - check ALL codes, see what o2 sensors are reporting.
The exhaust leaks, exhaust back pressure checks, are good suggestions/
If you replace all o2 sensors you need to clear the RAM* As jeep calls it, NOT just clear codes.
All you need to do is remove Neg battery terminal
*POWERTRAIN VERIFICATION TEST VER - 5
jtec is offline
post #14 of 14 Old 06-14-2019, 01:34 PM
WeezyBlue
I'm not going to prove or disprove your issue or claim I know what's happening. I just know my Jeep has thrown this code forever and with 5.13s and heavy (125lbs ea) 37s it still gets 14.5 mpg on the highway @70 (gps verified.) . I've had cats clog before. If you're flooring it to hold 60, you've got something up.
I don't have the issue on hand but there is a TSB out there referring to operating range of 02 sensors (I believe at start up)
KD8UCX
05 TJ Rubicon DD
82 Wagoneer Limited WIP
06 TJ SE Sold
WeezyBlue is offline
