Can you use 75w-90 synthetic gear fuild in your differentials? - JeepForum.com
post #1 of 4 Old 07-16-2010, 12:18 AM Thread Starter
Peezi
Quick question!
I am in the middle of changing my fluids on my 98 TJ and I noticed that I bought 75w-90 instead of the 75w-140, does this matter? Will performance be affected or should I just take it back and get the 75w-140?
Peezi is offline
post #2 of 4 Old 07-16-2010, 12:23 AM
RogueSpear2023
If you tow all the time I would get the 75w-140, but just normal use with the occasional towing 75w-90 will be fine, it's just a little lighter weight. I think the recommendation on JF is to run regular Dino oil on synthetic in the diffs, I believer there are some reports of synthetic causing the diffs to become much hotter driving around than regular Dino, plus Jeep recommends changing the diff fluid every 24,000 so no need to spend extra on synthetic, I change mine every summer if I don't go in the water over the diffs, if I do go in the water over the diffs they get changed when I get home.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #3 of 4 Old 07-16-2010, 12:29 AM Thread Starter
Peezi
So its ok to use if I go wheeling and do a lot of mountain driving? I do not tow.
Peezi is offline
post #4 of 4 Old 07-16-2010, 01:11 AM
BYuen
BYuen's Avatar
I use 80w90 in my diffs. 75w90 would be fine too. I wouldn't worry about it. Diff gears generally aren't too picky about the weight you use. Stick with the Dino stuff. You'll be fine. The only time I would use synthetic diff oil is if I lived in an extremely cold climate or hauled a bunch of stuff all the time. But even then, you can't haul much in a TJ... 2000 lbs max
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
75w-140 , 75w-90 , diff fluid , differential fluid , differential oil , gear oil , synthetic oil
Dana 44 rubicon rear limited slip gear oil, synthetic or regular gear oil what weight rutacon05 TJ Wrangler Technical Forum 6 09-16-2009 08:53 AM
Synthetic gear oil in the diff?? Swedejeeper TJ Wrangler Technical Forum 20 12-30-2008 08:47 AM
Gear Oil for Differentials? okstateAlum TJ Wrangler Technical Forum 9 11-26-2006 09:09 PM
Synthetic gear lubes DogPak TJ Wrangler Technical Forum 6 01-25-2006 04:00 PM
synthetic gear oil Spiderman TJ Wrangler Technical Forum 4 06-29-2004 05:02 PM
