Can't remove lower control arm - JeepForum.com
 2Likes
  • 1 Post By superj
  • 1 Post By 222Doc
post #1 of 5 Old 09-20-2021, 01:30 PM Thread Starter
TJBart
Greetings
I'm replacing my front control arms after a two of four developed slop in their bushings - they're 15+ years old. Had no issue on 3 but when I tried to remove driver side lower control arm I can not get the front bolt out - it hits the diff housing. See pic. I had the Jeep regeared a year or so ago but I don't remember him doing anything with control arm mounts.... Trying to get hold of the guy that did the work but haven't had any luck - of course..... Any suggestions are appreciated. Cut the bolt and get replacement? Best way to do that? Thanks for the help. Looking forward to getting out now that the temps are slowing dropping...
Cheers
Bart
TJBart is offline
post #2 of 5 Old 09-20-2021, 07:32 PM
Jeepsr4me
Just pull down on the bolt. It will come out.
Jeepsr4me is offline
post #3 of 5 Old 09-21-2021, 07:14 AM
superj
superj's Avatar
and maybe put a jack under the side of the axle to lift it a hair more while pull the bolt head down. if just pulling it doesn't work
tr21triton likes this.
the xj is the only jeep left in the driveway
superj is offline
post #4 of 5 Old 09-21-2021, 10:56 AM
rjgogo
Nothing a torch, sawzall or plasma cutter can't fix if it is really that stuck.
rjgogo is offline
post #5 of 5 Old 09-21-2021, 11:01 AM
222Doc
222Doc's Avatar
raise the axle side up to stuff, will have room then.
222Doc is offline
