Can I replace this plug for the fuel pump? - JeepForum.com
 2Likes
  • 1 Post By Jonny Jeep
  • 1 Post By PurpleTJ
post #1 of 8 Old 07-26-2021, 06:43 PM Thread Starter
PurpleTJ
PurpleTJ's Avatar
I need to fix some wiring and I'm not sure where to start looking for this plug. Where the fuel pump plugs into the wiring harness, right above the gas tank on the driver's side, I need to replace that plug, but only the connection on the Jeep side, not the fuel pump side. I found a damaged wire, just an inch away from the plug. Not enough slack to splice it. Can I buy just this piece somewhere? Scrap yards are out of the question, TJ's can't be found there.
Purple Jeep Club member #8
PurpleTJ is offline
post #2 of 8 Old 07-26-2021, 07:00 PM
TJ4Jim
Same issue on my 99, I cut the connector off the harness and on the bench I was able to de-pin the connector and salvage the pins, that was 2015 and still good today.
If you come to a fork in the road take it.
TJ4Jim is offline
post #3 of 8 Old 07-27-2021, 04:10 AM Thread Starter
PurpleTJ
PurpleTJ's Avatar
I'm realizing now that I could just jump the wire over the plug. Is that safe to do with the ground wire? I'm an electrical noob
PurpleTJ is offline
post #4 of 8 Old 07-27-2021, 04:37 AM
rcroane
Did you try Davey's Jeeps?
rcroane is offline
post #5 of 8 Old 07-27-2021, 05:26 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yes, just do it securely. And securely wrap black electrical tape around the splice(s).
Jerry Bransford is offline
post #6 of 8 Old 07-27-2021, 11:14 AM
Jonny Jeep
Jonny Jeep's Avatar
I replaced the loom side connector after having problems with it after changing my fuel pump. I can't remember where I got mine from (ebay maybe) but the part number is 5013984AA
Don't worry too much about any descriptions you find as it's used on multiple vehicles for multiple locations. The part number is the important bit.
Here's one, only $10
https://www.ebay.com/itm/33315067269...evt=1&mkcid=28
Jerry Bransford likes this.
Jonny Jeep is offline
post #7 of 8 Old 07-27-2021, 02:34 PM Thread Starter
PurpleTJ
PurpleTJ's Avatar
Awesome, thanks everyone!
PurpleTJ is offline
post #8 of 8 Old 07-28-2021, 12:29 PM Thread Starter
PurpleTJ
PurpleTJ's Avatar
Spliced the wire, dropped in a new battery... Jeep starts for the first time in 2 years. Pulled out of the garage.... dumping brake fluid. Driver's side rear brake line is rotted out by the frame rail. Time to start yet another rusty, expensive adventure on this Heep
PurpleTJ is offline
