Cam Shaft Position Sensor? - JeepForum.com
post #1 of 5 Old 10-29-2009, 06:23 PM Thread Starter
PullMeSideways
PullMeSideways's Avatar
2010 JK Wrangler
Well my jeep has had trouble starting. Normally takes 2-3 turns of the key to get her cranked.
I replace the fuel regulator/check valve thing. That didn't work.
So now all of a sudden the check engine light pops on. The jeep is an '02 with a I6 and Auto tranny.
I took it to the auto zone to see what codes were coming up and I can't remember the code but he said is was showing the "Cam Shaft Position Sensor" as the issue.
A) What is this and is an expensive part
B) Is it a hard job?
I think the Jeep knows I am going to trade her in on a new one.
Any help would be appreciated, because you know the stealership is going to kill me on my trade if there is a check engine light on.
2010 2dr Rubicon - Mango Tango!
Colorado Jeep Club Member #11
Former Jeeps:
2002 TJ Sahara, 2007 JK Unlimited Sahara, 2004 WJ & 1986 CJ-7
PullMeSideways is offline
post #2 of 5 Old 10-29-2009, 06:25 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Simple job, not expensive and located on top by 2 torx screws and a plug, where the distributor would normally go.
GOLENJEEPTJ is offline
post #3 of 5 Old 10-29-2009, 06:28 PM
GOLENJEEPTJ
Why are you selling the 02?That's the year of mine!
post #4 of 5 Old 10-29-2009, 06:36 PM Thread Starter
PullMeSideways
2010 JK Wrangler
I use to have a company car, now I took a job where I have to commute and my jeep is mostly built for off road comforts, not commuting comforts.
I am going to miss it.
Former Jeeps:
post #5 of 5 Old 10-29-2009, 06:41 PM Thread Starter
PullMeSideways
2010 JK Wrangler
I know I am a noob on this but where the heck would the distributor go? A picture would be great if possible.
Thanks again!
Did I mention JF Rocks!
Former Jeeps:
Crankshaft Position Sensor or Camshaft Position Sensor? TennesseeTJ TJ Wrangler Technical Forum 20 07-31-2017 12:22 PM
ESP problem related to Crank shaft position sensor? joeranger JK Wrangler Technical Forum 7 10-27-2009 01:49 PM
Possible broke crank shaft position sensor mrbigglesworth YJ Wrangler Technical Forum 3 06-18-2007 06:56 PM
P0340 - Cam Shaft Position Sensor Error barkdog TJ Wrangler Technical Forum 1 12-27-2006 03:43 PM
Crank Shaft Position Sensor burned up trotter YJ Wrangler Technical Forum 3 04-14-2005 06:28 PM
