Calling all transmission experts NV3550 - JeepForum.com
post #1 of 7 Old 09-29-2015, 08:55 AM Thread Starter
scottpollack
Yes I have NV3550 noise, but its not your typical one.... Here are the details...
Ok, 5th in my AX-15 went south so I decided to buy a NV3550 with 60k miles on it to replace it with. Added a Hurst short throw shifter and threw away the stock xfer case linkage.
I used Redline MT for the transmission. I run 33x12.50s, drive it like I stole it so I went with the 90 instead of the MTL. Shifts great no chatter, vibrations nothing.
EXCEPT what sounds like a spinning bearing sound. Here's the specifics:
1) Only heard at above 15 mph
2) Wheel speed origin
3) Clutch in/clutch out, in gear/out of gear
4) 2 wheel drive or 4 hi
5) all fluids in tranny, xfer case, both diffs at proper levels
6) "tinkered" with 4x4 shifter to ensure there wasn't a linkage adjustment with new linkage
7) Ujoints (all 4) are all tight and solid, no slop
8) brand new clutch, pressure plate, throwout bearing
9) brand new pilot bearing
I have read across the forums that the NV3550 is known for a "marble in a paintcan" sound. This sounds literally like a bear race popped off and is running on a shaft somewhere. It doesn't seem to change speed when I go faster, but COULD be at that point the wind becomes a factor on hearing.
If I am coming down my neighborhood street you can hear it on the sidewalk so I wouldn't say its "quiet".
I did not change the input shaft bearing on the transmission....didn't think @ 60k miles it would really be necessary. Is it possible that is what it is, or do I have a dorked up ujoint or WHAT, or did I develop a failing wheel bearing
Please help!
scottpollack is offline
post #2 of 7 Old 09-29-2015, 10:39 AM
rondak46
rondak46's Avatar
You have to use synchromesh, synchromax or compatible fluid. I use Royal purple.
rondak46 is offline
post #3 of 7 Old 09-29-2015, 10:52 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Originally Posted by rondak46 View Post
i use royal purple.
x 2.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/BM brakes
99' XJ / 5.5" lift / Rancho shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #4 of 7 Old 09-29-2015, 11:24 AM
J03_TJ
J03_TJ's Avatar
... I use royal purple.
x3
J03_TJ is offline
post #5 of 7 Old 09-29-2015, 12:16 PM
2jhanna
RedLines MTL mets synchromesh specs, their MT90 does not.
I don't know enough to know whether your problem is fluid related or not, but if you have been using MT90, that doesn't meet the spec.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #6 of 7 Old 09-29-2015, 06:26 PM
rays00tj
When I purchased my TJ in 2000 I called Redline and asked what they recommended for the NV3550. I was told a 50/50 mix of MT90 and MTL. I ran that in the transmission for the first 10,000 miles with a nice shifting transmission so I don't think running MT90 is going to cause the problem he is experiencing. I would think the 1-2 shift might be stiff until the transmission warmed up. I am running Pennzoil Syncromesh currently because it was easy to get when I was on a wheeling trip. I have run Redline MTL for a few thousand miles without any problem. I always change the fluid when I submerge the transmission in deep water so I have used a few different fluids, all have worked fine.
rays00tj is offline
post #7 of 7 Old 09-29-2015, 06:54 PM
chris142
Originally Posted by J03_TJ View Post
x3
x4
chris142 is offline
noise , nv3550
