cab air filter install (pic) - JeepForum.com
 1Likes
post #1 of 18 Old 07-20-2007, 09:05 PM Thread Starter
fish4life
So following Stu's friend's idea i thought i'd add one myself, because i'm sick of cleaning the jeep after every drive on dusty logging roads....
I wasn't about to spend money on a KN&N nor do anything fancy, so this is what i did ....
I took measurements of the hole and went to my local Canadian Tire. I bought a Motormaster filter for $8 (CAD) that seemed to fit the dimensions. (The green stuff is filter material for a furnace. The hole "tapers" to one side, and causes the fins of the filter to bunch up, creating a gap, so i filled that with this stuff)
This filter fits perfectly, the fan blows nicely, but it got me thinking .... would a filter like this put too much stress on the fan as it sucks air through???? anyone know
fish4life is offline
post #2 of 18 Old 07-20-2007, 09:13 PM
EvilM0nkey
EvilM0nkey's Avatar
what do you have holding the filter down? Looks like it would come off with a few good bumps
EvilM0nkey is offline
post #3 of 18 Old 07-20-2007, 09:16 PM Thread Starter
fish4life
It is a very tight fit, but i have put a strip of duct tape around it, mainly to close any "gaps" where dirty air could leak through...
The rain stopped so i went outside to run the fan at full blast and i answered my own question about the filter "stressing" the fan..... at full blast the fan sucked my hand to the filter easily, it could probably draw air through 5 of these
post #4 of 18 Old 07-20-2007, 09:29 PM
nolo263
thats a good idea but where does it go??? I cant tell from the pic where that part is on the jeep.
nolo263 is offline
post #5 of 18 Old 07-20-2007, 09:31 PM
RLD831
RLD831's Avatar
It is on the passenger side, right under the cowl.
RLD831 is offline
post #6 of 18 Old 07-20-2007, 09:33 PM Thread Starter
fish4life
don't have any photos of the cowl, but it's the "grill" right below your windshield wipers. you can remove that part....
you can see it here on stu's website
http://www.stu-offroad.com/body/cleanair/cleanair-1.htm
there you can see the rectangular hole where your fan draws air, and dust as well
post #7 of 18 Old 07-20-2007, 09:54 PM
rmb2485
rmb2485's Avatar
Will that filter just sop up water when it rains and water goes down into the cowl through the center vent?
rmb2485 is offline
post #8 of 18 Old 07-20-2007, 09:56 PM
PaulL
That's good.
I might just get some foam, but I was also thinking of looking for a filter that would just about fit ... there are lots of sizes to choose from.
PaulL is offline
post #9 of 18 Old 07-20-2007, 09:58 PM
BYuen
BYuen's Avatar
Shouldn't be a problem with the stress. I hope not. The cabin air filter for the WJs you can buy basically does the same thing. Great idea I might have to do what you did myself, but yes tell us if it does leak.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #10 of 18 Old 07-20-2007, 10:05 PM
FifteenCents
FifteenCents's Avatar
I don't get it.
Why?
The above post is my opinion and I have no facts to prove it... :)~
The ultimate TJ owners only forum
FifteenCents is offline
post #11 of 18 Old 07-20-2007, 10:06 PM Thread Starter
fish4life
how can this possibly be any worse then the naked exposed hole that's been there for 10 years?
Also, when water goes into the cowl, it will run through the slot at the bottom, down behind he engine
Maybe i didn't understand your question
post #12 of 18 Old 07-20-2007, 10:07 PM
nolo263
Aha I looked at the site and now I understand. thanks.. That would work great especially here in south texas. Lots of dust here..
nolo263 is offline
post #13 of 18 Old 07-20-2007, 10:30 PM
rmb2485
rmb2485's Avatar
Well, I guess I'm thinking that with just the hole there would be some drain holes down there so the water drains before reaching the fan. With the filter, it it gets wet it will hold the water and you will have a humidifier instead of a hvac system...
I like this idea but I have never looked under my cowl so I don't know whats really goin on down there. Will the filter get soaked or is it protected from water through the vent in the cowl?
rmb2485 is offline
post #14 of 18 Old 07-20-2007, 10:47 PM Thread Starter
fish4life
The "drain slot" in the cowl is the lowest point, any water that gets in there SHOULD drain out the bottom
on top of that, the filter is raised about 1" above any of the metal surfaces, so if any water gets in the cowl from the sides, it will likely go around the filter
so hopefully it will stay dry, but we have yet to see. Now you ahve me thinking though .... because the write up on Stus site uses a Kn&N filter taht's located AWAY from the fan hole, closer to the cowl opening where water could get on it (then again maybe he lives where they have no rain)
you can see the raised "lip" in this photo, on top of which the filter sits
post #15 of 18 Old 10-22-2019, 06:32 AM
RAB123
Time for a Revive lol
has anyone tried to put more slots in the cowl to facilitate more air available for the cabin air intake and also possibly easier to plumb engine air availability ?
RAB123 is offline
Fuel Filter Install. cactus jeep YJ Wrangler Technical Forum 11 01-11-2008 07:51 AM
motorcraft 2100 install, do i need a new fuel filter? rolledthatho YJ Wrangler Technical Forum 13 06-12-2006 09:47 PM
fuel filter and pressure regulator install LIVE2SURFAZ TJ Wrangler Technical Forum 1 04-24-2006 01:15 PM
K&N Square Stock Filter or Round K&N filter??? SupaJosh TJ Wrangler Technical Forum 9 09-13-2005 04:59 PM
Fram Disposable Air Filter (Same Part Number Different Filter) julietkilo TJ Wrangler Technical Forum 7 07-15-2005 09:02 PM
