Bumpy AC Unit - JeepForum.com
post #1 of 4 Old 06-06-2021, 06:49 PM Thread Starter
JeepJeffW
JeepJeffW's Avatar
Bumpy Cruise Control Unit
1997 TJ with 4.0 and manual tranny.
Cruise Control works great until I hit a bump in the road. Then it shuts down. If the road is smooth I simply push in the activation button on the end of the switch and it comes on again and works fine, that's until I hit another bump and off it goes.
Repeat, for every bump we hit. I'm assuming there is a loose connection somewhere but am clueless how this system works. Where should I start looking to check this out. Totally uneducated when it comes to these systems so explaining things very simply would be appreciated.
"The government cannot give to anybody anything that the government does not first take from somebody else. You cannot multiply wealth by dividing it."
~~~~ Dr. Adrian Rogers, 1984
JeepJeffW is offline
post #2 of 4 Old 06-08-2021, 07:53 PM
TJ4Jim
Air Conditioning works great until I hit a bump in the road. Then it shuts down. If the road is smooth I simply push in the air activation button on the end of the switch and it comes on again and works fine, that's until I hit another bump and off it goes.
Sounds like an aftermarket installation, can you find something to identify the system.
If you come to a fork in the road take it.
TJ4Jim is offline
post #3 of 4 Old 06-10-2021, 03:48 PM Thread Starter
JeepJeffW
JeepJeffW's Avatar
I can't believe I said air conditioning instead of "cruise control" which you caught somehow. THANKS! Yes, it is an after market cruise unit that I think was made by Rostra and it looks to be an older unit. I'll include a picture of what it looks like below. It is mounted on the lower left side of the steering column. I cannot find any refrence to a wiring diagram or model number since it was on the jeep when I bought it. Worked great for a week or so and then all of a sudden this happened. Hoping I can fix it without too much damage. Here's a link to what it looks like.
https://www.ebay.com/itm/20322677530...0aAnkNEALw_wcB
post #4 of 4 Old 06-11-2021, 02:00 PM Thread Starter
JeepJeffW
JeepJeffW's Avatar
Success! I finally made time to work on this cruise control unit. Pulled the two pieces of the steering column cover apart alog with the plastic dash under the column. Followed the wires down to under the dash and found a little clip that the wires from the column lead to. Pushed on the clip and heard it snap into place. Must have worked itself loose over time. Took a test ride and it works great - even on the bumpity bumpity roads. Took me longer to get the screws back into the steering wheel cover than to fix it!
