Braking Problems - JeepForum.com
post #1 of 15 Old 11-24-2013, 05:05 PM Thread Starter
adamf19
Braking Problems
I have a 98 4.0 Auto.
We just got some snow this weekend and its the first time my jeeps been in the snow. It does great until I have to stop! The front brakes work fine and lock up if they need to but the back breaks are barely working. Sometimes if I hold the brake all the way in the rear wheels will still spin...
The brake pedal is pretty squishy and I have to push it pretty far down.
A weird thing is that when I'm in 4wd it stops like its supposed to.
Any ideas?
adamf19 is offline
post #2 of 15 Old 11-24-2013, 05:39 PM
JFM626
JFM626's Avatar
Sounds like you need to pull the rear drums to have a look your brake components. Once you get the drums off, you should be able to see a couple of things; fluid on the lining would indicate either a brake fluid or axle seal leaking. If they are dry next check the wheel cylinder for being seized by pushing at the top of each shoe toward the wheel cylinder alternately. They should move in and out easily, if not the cylinder is seized and needs replacement or rebuild. If all is still ok check the star adjustment mechinism, often they seize up too. Pull the little piece of metal away from the star and try to turn the star wheel with you fingers. It should turn easily.
If everthing up to this point checks out, put the drum back on and adjust the star wheel from behind untill the drum is dragging on the lining. Repeat all of above for the other side.
JFM626 is offline
post #3 of 15 Old 11-24-2013, 06:22 PM Thread Starter
adamf19
Okay thanks ill check that stuff tomorrow!
Do you have any idea of why it would stop a ton better when it's in fourwheel drive vs two wheel drive? I'd figure out would stop the same either way..
adamf19 is offline
post #4 of 15 Old 11-24-2013, 06:31 PM
durango-bob
durango-bob's Avatar
2006 WK
When you are in 4wd, you have the front and rear axles locked together. So when you apply the front brakes, all 4 tires are trying to slow you down.
durango-bob is offline
post #5 of 15 Old 11-24-2013, 06:41 PM Thread Starter
adamf19
Oh duh! That makes sense...
So basically if my rear brakes don't work well, the front brakes are doing all the work when im in 4 wheel drive
adamf19 is offline
post #6 of 15 Old 11-24-2013, 08:09 PM
apaTJ
The front brakes are stopping the entire drivetrain when you are in 4wd. In 2 wheel the front brakes are stopping the front wheels but nothings stopping the back wheels and since you have an auto it's spinning a little in loose terrain.
apaTJ is offline
post #7 of 15 Old 11-25-2013, 08:12 PM Thread Starter
adamf19
Found my braking problem!
They look pretty shot and theres brake dust/dirt everywhere. I figured I'd basically replace everything, including the piston cylinder thing. I'm assuming I can get most of the parts I need at Autozone.
I only tore apart the drivers side, and didn't see anything for the emergency brake... is it only something thats on he passenger side or is something missing?
adamf19 is offline
post #8 of 15 Old 11-25-2013, 08:30 PM
JFM626
JFM626's Avatar
In behind the axle where the wheel bolts on there should be a metal bar that runs between the front and back shoes. There will also be a cable that enters the braking area from behind the backing plate. If you have these plus a bit more, you have a park brake (functioning or not). After blowing up your picture, however, I do not see the self adjuster cable that should run along the inside of the back shoe. You may in fact have no park brake on that side. Do you have a working park brake at all?
JFM626 is offline
post #9 of 15 Old 11-25-2013, 09:53 PM Thread Starter
adamf19
hmmmm... I've only had it for about two months and have no need for the parking brake seeing its an auto and I don't live in a hilly area
I'll check if it works tomorrow. If not, is it something that fine to leave off disconnected unless its an easy fix?
adamf19 is offline
post #10 of 15 Old 11-26-2013, 05:21 AM
WranglerPete
I just did my rear brakes and when I pulled off the passenger side there was nothing at all for the emergency brake. The drum had a huge trench in the middle of it and the drum was corroded and pieces were missing. I doubt that side was even working.
$100 later from Advanced, $60 to a friend who helped me, and it is as good as new.
WranglerPete is offline
post #11 of 15 Old 11-26-2013, 09:25 AM
JFM626
JFM626's Avatar
My wife drives an auto as well, and never uses the park brake. When I did the brakes earlier this year all the cables were siezed. Replaced them and everything was fine, she was good about using the park brake for a while, but old habits die hard, and I suspect I will be replacing them again in a few years. I suggesr you fix them, and use the park brake as well as the park position. Use the park brake first and then put it in park. All that is hollding you back in the transmission is a small piece of metal, if that breaks, you will have a much greater expense on your hands.
JFM626 is offline
post #12 of 15 Old 11-26-2013, 09:36 AM
bobjp
Those rear brakes don't look bad to me. There appears to be plenty of friction material left. Likely, they just need adjustment. You will be surprised at how much more balanced the braking will be after a simple adjustment.
Turn the star adjuster until the drum just barely rubs on the shoes. Unless you want to work through the window in the backing plate, you'll have to take the drum on and off. The drum probably has an unworn ridge so you'll want to push it all the way on before testing for rub.
There are parking brake components on both sides. If you don't want a parking brake, no, you don't have to fix it.
97 TJ sport.
bobjp is offline
post #13 of 15 Old 11-26-2013, 10:24 AM
GilaMtnJeep
GilaMtnJeep's Avatar
I have the same issue show up from time to time. When I did my rear brakes (about 5k miles ago) I had a leaky wheel cylinder but everything else was fine. Recently my rears seemed like they were weak and I had to adjust them. The self adjusters are fine and assembled properly but it seems like they just don't "adjust" for wear like they should. Once I made the adjustment the rears were good and the parking brake started working again, too.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #14 of 15 Old 11-26-2013, 10:50 AM
bobjp
Yeah, the self adjusters don't work on this Jeep in my experience. I adjust the brakes when I rotate the tires.
97 TJ sport.
bobjp is offline
post #15 of 15 Old 11-26-2013, 11:58 AM
JStMarie
JStMarie's Avatar
Brakes look shot to me. Not much meat left, if any. I would completely re-do them. Shoes, drums, springs, cylinders, everything... I'm not usually opposed to salvaging what I can during repairs but when it comes to brakes I don't mess around.
This is not just your parking brake, it is your emergency brake. Most states require they function in order to be on the road. Even if your state does not, I'd get it functioning properly, especially if you decide to keep ANY of the parts visible in that picture.
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is offline
