brake lights question - JeepForum.com
post #1 of 7 Old 07-24-2003, 05:39 AM Thread Starter
guest
Guest
ok my 3rd brake light works, (cyclops ones above spare) but my main back 2 ones do not work, they light up with headlights on, the turn signals in them work, and i did a search.
Seems it might be teh "multi function switch" anyone know where this is located at on a 99 TJ? before I get out teh manual.
TIA
guest is offline
post #2 of 7 Old 07-24-2003, 06:35 AM Thread Starter
guest
Guest
ttt
guest is offline
post #3 of 7 Old 07-24-2003, 07:00 AM Thread Starter
guest
Guest
ok, i did some reading, seems if i turn teh 4 ways on and they don't work, then its the multi function switch, but if they do work, then there is a brake light switch i just need to replace? anyone wanna back this up for me?
guest is offline
post #4 of 7 Old 07-24-2003, 09:23 AM
Dee Cue
Dee Cue's Avatar
If your 3rd brake light works when you press on the brake pedal then I doubt it's the brake light switch... It smells like the multi-function switch to me, but I'm sorry I don't have a schematic to tell you for sure and help you on what to look for...
BTW the multi-function switch is the turn signal/headlamp switch on the left hand side of your steering column.
Blk, '05 LJ, 6-spd, 3" Zone SL, 33" BFG AT on Soft 8's
Dee Cue is offline
post #5 of 7 Old 07-24-2003, 09:26 AM Thread Starter
guest
Guest
in another thread the guys 4 ways didn't work either, so he replaced the multi function switch, and it worked, my 4 ways work fine. just teh 2 back brake lights don't work.
guest is offline
post #6 of 7 Old 07-24-2003, 09:39 AM
Dee Cue
Dee Cue's Avatar
It could still be the multi function switch... Again it all depends on the design. Do you have a schematic?
Dee Cue is offline
post #7 of 7 Old 07-24-2003, 09:43 AM Thread Starter
guest
Guest
whats that?
lol
well i'd sooner start with a $12.99 part then a $50 one.
guest is offline
89 YJ Electrical Issues blinkers/ dash lights come on with Brake lights Cajun90YJ YJ Wrangler Technical Forum 9 10-03-2010 05:33 PM
brake lights question 97tjeff TJ Wrangler Technical Forum 1 12-08-2009 07:53 PM
3rd brake light and reverse lights on tire carrier question yellowismellow TJ Wrangler Technical Forum 6 01-06-2009 11:57 AM
rear brake lights/ regular lights dilemma yjcrawler YJ Wrangler Technical Forum 1 08-20-2007 03:52 PM
brake lights, ok; tail lights/side markers/turn signals not.... help? LoneJeeper TJ Wrangler Technical Forum 2 09-12-2005 08:18 PM
