Brake light on and SIX beeps? - JeepForum.com
 9Likes
post #1 of 17 Old 11-09-2019, 09:06 PM Thread Starter
Cob731
2006 LJ. Perplexing issue; when I come to a stop and I put the transmission into Park and apply the parking (e-brake) brake, the brake light comes on (as it should) and it beeps six times then stops. If I wait six seconds after putting the transmission in park before applying the parking brake, only the light comes on (as it should), but no beeping. Brakes are functioning properly at present time. NORMAL function? Any info/ideas would be appreciated. Thanks
Cob731 is offline
post #2 of 17 Old 11-10-2019, 09:18 AM
Jeepsr4me
This has to be part of the selector on the side of trans.
With the Ebrake on if you put in gear it makes that noise.. Its to let you know so as not to mess the brake up..
Sounds like the selector is not quiet out of gear yet when you put brake on,.
Could just be worn or needs adjustment. If it begins to not start without wiggling the shifter in and out of park neutral then you know what is broke.
Cob731 likes this.
Jeepsr4me is offline
post #3 of 17 Old 11-10-2019, 04:21 PM
mukluk
mukluk's Avatar
It's normal, my manual transmission LJ does the same thing.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #4 of 17 Old 11-11-2019, 04:25 AM
AjRagno
AjRagno's Avatar
Originally Posted by Cob731 View Post
...when I come to a stop and I put the transmission into Park and apply the parking (e-brake) brake...
I'm not sure about the beeping but with an automatic transmission it's important to apply the parking brake in Neutral, then remove your foot from the brake and shift into Park. Doing this places all of the weight of the vehicle on the parking brake. This will reduce wear on the parking pawl, completely eliminates tension on the shift cable, and reduces the risk of breaking the plastic rod that engages the shift interlock.
AjRagno is offline
post #5 of 17 Old 11-12-2019, 03:04 AM
Jonny Jeep
Jonny Jeep's Avatar
The park brake warning sounds when the handbrake is applied and the vehicle is still moving. The PCM must still be sensing input from the VSS as the vehicle settles.
Cob731 likes this.
Jonny Jeep is offline
post #6 of 17 Old 11-12-2019, 02:17 PM
fromme
fromme's Avatar
2015 JK Wrangler
Cant help but wonder if your parking brake shoes are bad or severely out of adjustment, which would cause the vehicle to roll slightly after releasing the brake. Which in turn the vss would send a signal to the pcm indicating the vehicle is moving with parking brake on, as said above.
2015 JKUR
fromme is offline
post #7 of 17 Old 11-12-2019, 04:27 PM Thread Starter
Cob731
Didnít think of that! Iíll check it out. Thanks
Cob731 is offline
post #8 of 17 Old 11-12-2019, 04:29 PM Thread Starter
Cob731
Thanks for the suggestion; been doing that for years.
Cob731 is offline
post #9 of 17 Old 11-12-2019, 04:35 PM Thread Starter
Cob731
All good thoughts!
The consistent indication is the six beeps. If I put the transmission in park and count six seconds before applying the E brake, then the beep doesnít happen; any application of the E brake before the six second count is finished will result in beeps for the remaining number of the six second count.
Cob731 is offline
post #10 of 17 Old 11-12-2019, 09:41 PM
bonza
All good thoughts!
mines a manual and does the exact same thing since owning it from new. seems to be another quirk with the 05-06 models.
I find it annoying but have become accustomed to it and tend to wait a few seconds before apply the hand brake
mukluk and Cob731 like this.
2005 TJ Light Khaki
bonza is offline
post #11 of 17 Old 11-13-2019, 09:41 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
CRIKEY! None of my 05-06 Jeeps ever did that. It must be a backasswards, back of nowhere, Victoria, Australia thing. G'day mate.
bonza likes this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/BM brakes
99' XJ / 5.5" lift / Rancho shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #12 of 17 Old 11-13-2019, 09:44 AM
TheBoogieman
Distubed Jeepaholic
Not true in the least bit.
Cob731 likes this.
post #13 of 17 Old 11-13-2019, 09:56 AM
TheBoogieman
Distubed Jeepaholic
As always, Johny Jeep is correct.
p.s. My spellcheck tells me that you spell your first name wrong. Must be a US thing Mr. Jeep.
post #14 of 17 Old 11-14-2019, 03:03 AM
Jonny Jeep
Jonny Jeep's Avatar
I suppose it depends how you spell Jonathan over there. I bet it 'corrects' aluminium too.
TheBoogieman likes this.
post #15 of 17 Old 11-14-2019, 09:57 AM
TheBoogieman
Distubed Jeepaholic
My name is spelled three different ways over here.
Boogieman, Boogeyman, Bogeyman. I think Rob Zombie (White Zombie) got it right.
Jonny Jeep and WSS like this.
