Blower motor runs only in defrost position - JeepForum.com
post #1 of 6 Old 09-22-2009, 02:51 PM Thread Starter
45hondo
Well, my blower motor stopped working in my 97 TJ. I did a search and found a lot of info, but none to address my symptoms. The blower will not work in any of the four speeds no matter what selection I make. ( A/C, upper vent, foot vent, defrost, etc.) Now if I hold the selection slide all the way to the right, in the defrost position, all four blower speeds work. Anyone with any ideas?
45hondo is offline
post #2 of 6 Old 09-22-2009, 08:50 PM
Itsjustme2see
I would say you have a bad A/C, Heater control head.
Itsjustme2see is offline
post #3 of 6 Old 09-22-2009, 10:51 PM
BulldogTJ98
BulldogTJ98's Avatar
This seems to be a common problem in TJs. Me and my two friends both have the same problem. With mine, i can let off the gas, and it will start working, then when i start going again it will quit, its annoying on a cold morning with the top off, i tell ya. That little flap in the vent hose likes to flap around when its not supposed to. I cant tell you the cure though. IF you figure it out, let me know.
My Build Thread:
'98 TJ 4.0L, AX-15 5spd, NP231, RE 4.5 rear, 3"&.75" BB front, JKS discos, 33x12.50 KM2s on Rock Crawlers, 3.73s, Dana30 front, Dana 44 rear, JB Conversions SS SYE, JKS HD Tierod, Warn 8274 Winch, Front Stinger and Rear stinger w/ tire carrier, Rokmen Corners, Aluminum Radiator, LED tailights, Rock Lights, KCs, K&N airfilter, Optima Redtop, Cobra CB and a Sony soundbar
BulldogTJ98 is offline
post #4 of 6 Old 09-22-2009, 10:58 PM
bry71518
There is a place that the vac. hose goes under the passenger side. behind the bat. is the plastic vac line and hose. it runs down the firewall and into a canister (I think). Check that. Follow the hose. If it's disconnected the control acts erratically. That was the problem with mine. Theres about a 1 1/4 inch rubber hose connection that became brittle and cracked. I just cut the rubber after the crack and pushed it back on.
*** I couldn't SEE where the hose went - I had to feel for where it connected. I can try to take pics if you need. Let me know!
Otherwise on the drivers side of the engine bay near the master brake, theres a T joint for the vac. lines. That may be the problem - either way it is the beginning of the hose segment I described above - you could follow it from there.
B
bry71518 is offline
post #5 of 6 Old 09-22-2009, 11:05 PM
bry71518
Whoops! It looks like you may have 2 problems... I had the same problems... the fan module is located under the dash near the passenger feet. It's a bear to get out. It's actually a sensor like thing that goes in the blower. I can snap a pic if you need. hard to describe.
check this link
https://www.jeepforum.com/forum/f9/bl...sistor-464122/
bry71518 is offline
post #6 of 6 Old 09-23-2009, 09:57 AM Thread Starter
45hondo
I found the problem! On the back of the Climate Control Slide Selector Switch, on the right hand side, there is a flat, 4 blade connector. The locking clip was broken and allowed the connector to back out. Apparently, when I was pushing on the right side of the panel, in the defrost position, the connector made enough contact to allow the bower motor to function. I repluged the connector, secured it with tape, and everything works as new.
45hondo is offline
If it's not my blower motor resistor, it's my what??? blower still doesn't turn on.. bortz1892 TJ Wrangler Technical Forum 13 08-02-2010 09:13 PM
Fan Blower Works But Stuck On Defrost GUNNY STEVE TJ Wrangler Technical Forum 7 06-21-2009 06:40 PM
Blower not working on 1st and 3rd position cornfield25 TJ Wrangler Technical Forum 9 06-16-2008 08:55 AM
blower only working defrost/feet -?? CDNjeepgrl TJ Wrangler Technical Forum 10 10-30-2007 04:33 PM
Blower motor won't run in defrost BB69 TJ Wrangler Technical Forum 9 10-16-2004 04:11 PM
