BIG tires on stock wheels - JeepForum.com
post #1 of 35 Old 07-30-2007, 03:31 PM Thread Starter
omgsideburns
I've got the stock 15x7 'ecco' wheels on my 03 tj x (I believe that is what they are called). I just picked up a set of 33x12.5 tires and a 3" BDS lift. I believe the backspacing on these wheels is 5.5.
The question is will I be able to run these tires on these wheels because of the offset. If not would a 1.25" spacer be sufficient?
I do NOT want new wheels. I like the stockers and the balloon look with my tires.
omgsideburns is offline
post #2 of 35 Old 07-30-2007, 03:32 PM
arbby
2005 KJ Liberty
You'll need spacers then. You will have rub with out them
|l,[___],
l---L--OlllllllO
()_) ()_)--o-)_)
Gone: 1993 YJ
arbby is offline
post #3 of 35 Old 07-30-2007, 03:34 PM
JJs99TJ
Guest
x2 on what arbby said, plus you may need to extend your
steering stops to keep the new tires from rubbing at full
lock
JJs99TJ is offline
post #4 of 35 Old 07-30-2007, 03:59 PM Thread Starter
omgsideburns
thank you very much.
What kind of rubbing are we talking about? Spring perch contact, or just on turning? In case I don't have my spacers when I get the lift on and I feel like getting my tires on. =)
from what i've read steering stop adjustments are necessary for most big tires so no big deal there.
post #5 of 35 Old 07-30-2007, 04:09 PM
06WranglerX
Isnt that a bit to wide of a tire for 12.5 inch wide tires, isnt it advised to run atleast a 15x8 when you go above 10.5 inch tire width?
Originally Posted by lumpster View Post
he made it clear when he said he was. He didnt ask for a photo ID of you did he.
People need to be a little more trusting, Its not like we are on a convict and rapist forum.
Upon further reflection I've decided I've had enough of this BS and you are now on my ignore list.
06 Red Wrangler X 6 speed hard top
Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff.
06WranglerX is offline
post #6 of 35 Old 07-30-2007, 04:14 PM
GaytorHater703
yea spacers....they come in sets of 2....i got 3 for sale...so if you get a set of 2...and get my 3...you will have an extra for your spare to fit on a tire carrier....same issues with back spacing on most of those....PM me if interested..i got a thread in the for sale section as well
GaytorHater703 is offline
post #7 of 35 Old 07-30-2007, 04:42 PM
jeepbro's
as far as rubbing, it will be on the spring perches, and when turning, the tire will hit the frame near the swaybar and the lca,( i've got 33x12.5's) i just installed 1.5" wheels spacers, and i dont rub anywhere, and i can turn the wheel all the way with out any rubbing
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline
post #8 of 35 Old 07-30-2007, 05:11 PM
KI4KWF
post pics! im not really sure what kind of wheels you're talking about....
KI4KWF is offline
post #9 of 35 Old 07-30-2007, 05:16 PM
TAMUJeep
Guest
I have 35 x 12.5 on stock canyons with a 1.5 in spacer and don't have any rubbing...but all jeeps are different.
TAMUJeep is offline
post #10 of 35 Old 07-30-2007, 05:42 PM
KI4KWF
i want some canyons for my BFG 32x11.50 to skinny it up a bit
KI4KWF is offline
post #11 of 35 Old 07-30-2007, 08:13 PM Thread Starter
omgsideburns
thanks for all the words guys!
post #12 of 35 Old 07-30-2007, 09:08 PM
claytonandson
claytonandson's Avatar
i put 33/9.50/15 radial at's on my stock eccos,of course i did put a2" OME spring/shock lift on.
yellow jeep club #343
IAFF /FF's OF WASH. D.C. EMERALD SOCIETY/CHARLES COUNTY RESCUE SQUAD 51
claytonandson is offline
post #13 of 35 Old 07-30-2007, 09:19 PM
mike06X
i did the same thing on one of my jeeps because i paid extra for the ecco's when i bought the jeep and really felt the urge to keep them..
first, the will rub quite a bit, 10.5 wide will rub on the ecco wheels on the control arms..
second, the tires will not balloon the way you are thinking; 12.5 are wide but not balloon tires; you'll end up with a slight balloon and a overly bulged tread area that won't look good unless you run with 12 psi..
32x11.50's wouldn't be too bad, would fit the 3" lift great and if you added spacers, would give you awesome clearance.
84 CJ7 - AMC360 & T727 | 35 BFG-KM2
mike06X is offline
post #14 of 35 Old 07-30-2007, 09:57 PM Thread Starter
omgsideburns
i've already got the tires so theres no changing that. i ordered spacers so we'll just see what happens.
post #15 of 35 Old 07-30-2007, 10:46 PM
KennyTJ
Guest
I've got 32x11.50 on stock 15x7's
Only rub at full steering wheel lock a little. No rubbing even disco'ed with 3" now with 4" not even close!
KennyTJ is offline
Stock tires on New wheels Maldoro JK Wrangler Technical Forum 0 09-19-2008 11:26 AM
stock wheels and tires WOO! JEEPS! TJ Wrangler Technical Forum 1 08-04-2007 09:34 PM
Upgraded Tires and Wheels; what to do with stock tires/wheels? rtilotta JK Wrangler Technical Forum 5 06-05-2007 07:08 PM
31" Tires and Stock Tires on New Wheels arcteryx23 TJ Wrangler Technical Forum 9 01-18-2006 10:26 PM
Will the stock wagon wheels (15x7) with 31x10.50 tires fit on without wheels spacers? BIGCRAZYBELL TJ Wrangler Technical Forum 4 11-28-2004 01:10 AM
