Best Short Arms? - JeepForum.com
post #1 of 22 Old 07-07-2006, 04:52 PM Thread Starter
ej's tj
ej's tj's Avatar
Best Short Arms?
So I am loving my LJ with the DPG Ultimate kit , the only problem is when I hit a good size bump it feels like the front axle is on the verge of over powering the stock control arms and departing from my Jeep . My guess is that the stock arms are 1. not operating at their optimal angle due to the lift and/or 2. are at an increased disadvantage due to the angle and allow for more unintentional movement than before. It is not extreme or dangerous it is more of an annoyance and being a little a.r. I would like to fix it right...... suggestions?
2005 Unlimited Rubicon bright red, wet okole, 2 1/2" (more like 3"+) HD OME 1 1/4" JKS BL, JKS Discos, 1" JKS MML,28575R16 BFG MTs, Custom HD rear bumper, 2 year old Akita,
9500 lb. milemarker winch, kilby gas tank skid, home made rear bumper and tire carrier, lite dot taillights, more to come!!!!!!
Integrity is a rare find!
ej's tj is offline
post #2 of 22 Old 07-07-2006, 07:04 PM
otisdog
2008 WK
Really the only way to deal with it is with a longarm kit. You could get adjustable lower arms and adjust them a tad longer than stock [lifting shortens the wheelbase]. But the improvement would be minimal. That's the disadvantage to short arm lifts. The increased angle of the CA arms transmits more bumps to the frame instead of into the springs. You do gain strength with aftermaket CA's but you really need to get some that have a means of flexing. The RE's, Curries and JKS all have a means of flexing which take some of the stress off the CA mounts.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #3 of 22 Old 07-10-2006, 05:59 PM Thread Starter
ej's tj
ej's tj's Avatar
thanks
Thanks, I would really like to get the Nth degree short arms but at $1200 for the set I think going to a long arm would be better....unfortunately my cajones are not large enough to cut mounts off my 2005 Jeep frame....
ej's tj is offline
post #4 of 22 Old 07-10-2006, 06:38 PM
Expat
Frequent flyer
Expat's Avatar
Get the JKS adjustables from DPG. Many have reported HUGE ride improvements after adding them. I started with them(JKS arms) and run RE 3.5" coils and have a nice ride.
05 RME Fire Red
3.5" RE springs, JKS F&R adj track bars, JKS adj CAs (all 8), OME LT shocks, JKS quicker discos, JKS 1.25" BL, MORE BP MML, 35" Cooper SSTs on 057 Eagle Alloys, 4.56s Detroit lockers, Alloy USA front and rear axles, Currie HD steering, 52" Hanson front bumper, Warn 9.5ti with in-cab control, Kilby steering box skid, Jeeperman rear bumper/tire carrier, Jeeperman trail skidz, 33 Eng TT, JB SSSYE, TW driveshaft, and lots more........
2007 WK Overland Steel Blue..wifes
1997 ZJ Laredo...sons
2004 GMC 2500 HD Duramax Diesel..My TV and DD and Lance camper carrier
2003 Chaparral 223 deck boat
Originally Posted by kjp98TJ
drop the purse, and hit it.
Expat is offline
post #5 of 22 Old 07-10-2006, 08:05 PM
jrtdogbone
jrtdogbone's Avatar
I'm running RE Adjustable CA with Super Ride Bushings. They ride quite nice with the OME 4" Springs and Long Travel Shocks!
The Dog
The Dog 😎
2004 Jeep Willys
2006 Jeep Unlimited
jrtdogbone is offline
post #6 of 22 Old 07-10-2006, 08:47 PM
Polaris
Polaris's Avatar
If you decide to go with RE arms I woudn't go with Super-Ride bushings. They put more stress on the brackets which will cause them to fail eventually in comparison to the rebuildable and really flexible Super-Flex joints. Super-Ride joints also offer a much harsher ride in comparison to Super-Flex joints. I run all eight adjustables... great ride!
2000 TJ Sport, 3-speed slushbox
HP30, ChroMoly shafts, Ford 8.8 rear, 4.10s 35s
ORIGINAL Black Jeep Club Member #34
Polaris is offline
post #7 of 22 Old 07-10-2006, 08:48 PM
JeepGal
JeepGal's Avatar
RE adjustables with the Heim Joints
JeepGal is offline
post #8 of 22 Old 07-10-2006, 08:51 PM
dirtgrip
dirtgrip's Avatar
Currie CA's with Johnny Joints: http://currieenterprises.com/cestore/johnnyjoints.aspx
Large vacuum leak sucking all the dead presidents out of my wallet.
dirtgrip is offline
post #9 of 22 Old 07-10-2006, 08:53 PM
Polaris
Polaris's Avatar
RE does not use heim joints.
Polaris is offline
post #10 of 22 Old 07-10-2006, 09:13 PM
jrtdogbone
jrtdogbone's Avatar
That's your preference not a fact. The super ride offer a much better on road ride. The super flex joints may offer slightly better flex, but rquire a great amount of maintance.
It about personal preference, everyones is different!
The Dog 😎
2004 Jeep Willys
2006 Jeep Unlimited
post #11 of 22 Old 07-10-2006, 09:40 PM
redrock4x4
redrock4x4's Avatar
Fact is Super Ride arms will put far more stress on your LCA mounts than the Super Flex arms. Super Flex arms may not necessarily flex anymore, but they will take a lot of stress off the control arm mounts, which are already prone to failure.
Another fact, at least in our area of the world, is that Super Flex joints will out last the OEM rubber bushings on a Jeep that sees any significant trail use. They do require occasional greasing, but I wouldn't call that a great amount of maintenance, especially considering the fact that they should outlast the rubber bushings and they're rebuildable. Old style Tera arms for instance, require what I would consider a great amount of maintenance.
I would also say as a fact that you will notice little to no difference on road between a Super Flex and a Super Ride arm. The names really are misleading. There is a small difference, but most people can't even notice it. I've tried both and I can't tell a significant difference, and I tend to be pretty picky .
I personally wouldn't run a control arm with rubber bushings at each end on a Jeep that sees ANY trail use. I see no benefit on road, and I would expect the bushings to wear quickly or the control arm brackets to fail overtime.
In regards to control arm preference, I like the RE Super Flex arms as well as the Currie Johnny Joint arms.
redrock4x4 is offline
post #12 of 22 Old 07-10-2006, 11:15 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
So if I show you a set of RE arms with rod ends (Heim Brand) will you apologize for being wrong?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #13 of 22 Old 07-11-2006, 06:45 AM
BillR
BillR's Avatar
x2 on the JKS arms. VERY beefy, great flex and a great ride.
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #14 of 22 Old 07-11-2006, 08:05 AM
redrock4x4
redrock4x4's Avatar
old timer
post #15 of 22 Old 07-11-2006, 08:49 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by redrock4x4
old timer
Shush, you're supposed to be quiet and not ruin my traps I set for folks.
Actually I did some trading for some stuff and that RE set of uppers with the rod ends on one end was in the batch. I gave them to Scott Hill I think when he destroyed some of his.
I'm glad you know I'm right. That way I don't have to make Scott take a pic and send it to me.
I am Savvy
mrblaine is offline
Why short arms suck less mrblaine TJ Wrangler Technical Forum 214 05-20-2010 08:52 PM
How high on short arms? Timothy_90 TJ Wrangler Technical Forum 18 05-29-2009 05:53 AM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 05:47 AM
Best TJ short arms smurison14 TJ Wrangler Technical Forum 16 08-04-2006 07:59 AM
short arms last hurray camoTJ TJ Wrangler Technical Forum 21 12-17-2004 09:08 PM
