Best OBD II scanner? - Page 2 - JeepForum.com
post #16 of 43 Old 10-11-2012, 12:42 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by stripperguy View Post
Wow, sure enough, the key thing works, P2098, whatever that is...
Still do want a scanner, auto parts stores are not always open when I can work on a vehicle, and this LJ is not the only vehicle...I sometimes buy and sell insurance wrecks.
http://www.wranglerforum.com/f5/p209...ml#post2638576
Jerry Bransford is offline
post #17 of 43 Old 10-11-2012, 12:46 PM
Barcus
Barcus's Avatar
Originally Posted by ftgiles View Post
A $20 Bluetooth adapter and the free Torque App for your Android phone. Does everything Scangauge does plus a lot more and looks a lot better doing it. And look mom, no cord.
i use this as well. very nice for the $25 i have invested in it.
98 TJ Currie arms-RC 2.5 coils-RC 2.0 shocks-1.25 BL-TF rear track bar-custom bumpstops-mud-scratches-gas.
Barcus is offline
post #18 of 43 Old 10-11-2012, 12:54 PM
tators
I bought a cheap OBDII scanner from amazon.com... was around $20 bucks... Works great..
tators is offline
post #19 of 43 Old 10-11-2012, 02:53 PM
Benderff
Benderff's Avatar
You can't go wrong with the ScanGaugeii. http://www.scangauge.com/
Benderff is offline
post #20 of 43 Old 10-11-2012, 03:11 PM
keithert
keithert's Avatar
Benderff, can you give more details on your mount?
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #21 of 43 Old 10-11-2012, 08:29 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
There is a TSB for this code for ‘05s. It is 18-028-06 you can see it in post #2 here:
P2096 & P2098
Rubi4MyMrs is offline
post #22 of 43 Old 10-11-2012, 08:40 PM Thread Starter
stripperguy
Thank you all for the info...Already checked for exhaust leaks, didn't find any. I will need to check into the reflash, and this weekend I can try the simple battery diconnect, otherwise, it sounds like an O2 sensor.
Whichever way it is, seems pretty straightforward.
1977 CJ5 is a CJ build ever really done?
2002 TJ gone
2005 TJ also gone
2005 LJ insurance wreck
stripperguy is offline
post #23 of 43 Old 10-11-2012, 08:54 PM
Benderff
Benderff's Avatar
Sure, not much to it. I cut the trim around the window (2003-2006 have it IIRC) and mounted the unit through the hole. The cord was easy to run under the trim and through the dash to the port. I wasn't to worried about cutting up the trim because I had to hack the corners up to fit the cage.
Benderff is offline
post #24 of 43 Old 10-11-2012, 09:23 PM
Hemrides
I have a Garmin 3760 Nuvi GPS. For $99 I bought their eco adapter and it reads the engine codes and provides a report on the gps. Works with any OBDII autos. On my 04 TJ it showed I had fuel issues twice. Once was a sensor in the tank, the other was the gas cap needed to be replaced.
Hemrides is offline
post #25 of 43 Old 10-12-2012, 08:29 AM
keithert
keithert's Avatar
Did you have to get an extension for the cord? My scanguage is at home and I don't recall how long the cord is.
keithert is offline
post #26 of 43 Old 10-12-2012, 09:58 AM
Benderff
Benderff's Avatar
Nope, it fit nicely. There is slack In the line, so it's not maxed out.
Benderff is offline
post #27 of 43 Old 10-16-2012, 02:15 PM
goofus
I've owned an Auto-Xray unit and it was good. Full operational monitoring (like it'll tell you your timing position, coolant temp, TPS position to the degree, etc).
goofus is offline
post #28 of 43 Old 10-16-2012, 02:29 PM
keithert
keithert's Avatar
Because of this thread I bought the OBDII bluetooth adapater and the Torque app. It makes a fun toy to play with. I've enjoyed testing the 0-60 times in my other car. In the Jeep I will continue to use the wired Ultaguage for day to day use. Too much hassle to setup the phone every time when using Torque.
keithert is offline
post #29 of 43 Old 10-16-2012, 02:32 PM
ftgiles
The Torque App has profiles that you can save for different cars...
ftgiles is offline
post #30 of 43 Old 10-16-2012, 03:19 PM
Ironhead
Ironhead's Avatar
and it automatically jumps from vehicle to vehicle depending on where the obd2 BT adapter is plugged in.
check out the mini adapters. mine was $60 a year ago, now there are several for less than $20. I got the mini so i could leave it plugged in all the time without fear of kicking it getting in or out
Ironhead is offline
