Best Manual Gearbox - JeepForum.com
 7Likes
post #1 of 22 Old 12-11-2019, 02:47 PM Thread Starter
Kiwi_TJ
Best Manual Gearbox
Hi Guys,
My 1997 TJ has the AX-15 5-Speed Manual gearbox it in. Since my Jeep had 250,000 km on it, and I have not plans to sell it, I figure that at some point the gearbox may need repair or replacing. I am running Redline MT-90 in it and changing it regularly to try and make it last as long as I can.
So if I did need to replace it, and I wanted to stick to a manual gearbox, what would be the best option?
  • Replace the AX-15 with another one.
  • Replace with the newer NV3550 5-Speed
  • Upgrade to the NSG370 6-Speed.
I would welcome any advice or opinions, as I do not know much about anything other than the AX-15, which I had heard was quite a sturdy gearbox, as long as you run the correct oil in it.
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
post #2 of 22 Old 12-11-2019, 03:19 PM
mukluk
mukluk's Avatar
I'd just stick with an AX15 unless a good 3550 practically fell in your lap for next to nothing. My personal opinion is the NSG370 isn't an upgrade from the previous five speed transmissions.
jeepguy03 likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 22 Old 12-11-2019, 04:00 PM
jeepguy03
Winning
jeepguy03's Avatar
+1
I'm not 100% clear on what would need to be done to get the other transmissions in there, but you know the AX-15 would be the easiest to put back in it, and it is a pretty decent transmission to begin with.
0331 head swap DIY:
"Build" thread:
Previous: 1990 XJ Limited, 2000 XJ Sport, 2000 XJ Sport
Current: 1998 Wrangler Sahara
jeepguy03 is offline
post #4 of 22 Old 12-11-2019, 05:06 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Stay with an AX-15 which is a better/stronger transmission than the NV3550 or NSG370 is.
Jerry Bransford is offline
post #5 of 22 Old 12-11-2019, 05:09 PM
BlueFl.Wrangler
Supporting Member
BlueFl.Wrangler's Avatar
+1
Not that I have any first hand exp. on this subject-- but have read a bit and the consensus seems to be that your current is a better one than what the latter TJ's have in them.
Stick with what you got.
BlueFl.Wrangler is offline
post #6 of 22 Old 12-11-2019, 06:34 PM Thread Starter
Kiwi_TJ
Looks like AX-15 is the go!
Hi Jerry,
Thanks for that, good to have confirmation of the best way to go when my current one wears out. I have found with Jeeps, it always pays to be prepared. Seems to be that it is normally cheaper to get another one from a dismantler than rebuild and existing one.
Kiwi_TJ is offline
post #7 of 22 Old 12-12-2019, 03:23 AM
Jonny Jeep
Jonny Jeep's Avatar
I'm running MT-90 too, although I don't change it regularly. Current mileage is around 198k miles/317k km.
MT-90 and MTL and the general recommendations on here for the AX boxes, but interestingly neither is what Redline recommend. Redline themselves recommend their 75W90NS gear oil. I'm going to try it the next time I change my oil.
Jonny Jeep is offline
post #8 of 22 Old 12-12-2019, 06:49 AM
JeffBowser
JeffBowser's Avatar
You can buy a brand new AX-15 from several retailers for around the same price as a rebuilt. Just replaced mine this year after an internal seal failed and it ran dry on the way back home.
Hi Jerry,
JeffBowser is online now
post #9 of 22 Old 12-12-2019, 07:37 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Upgrade it to a 32rh.
Wheelin98TJ likes this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/Black Magic brakes.
99' XJ /4.0L-AW4/ 5.5" lift / Rancho RS5000X shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #10 of 22 Old 12-12-2019, 02:33 PM
Jerry Bransford
Administrator
X2, that's what I did and it was right up there with installing front and rear lockers in terms of offroad benefits.
TheBoogieman likes this.
post #11 of 22 Old 12-12-2019, 03:47 PM
Maverickxeo
Maverickxeo's Avatar
My dad's 99 has an AX15 and my 02 has an NV3550.
Of the two, my dad's seems 'smoother' but he has problems with second gear which arose at a lower mileage than what my NV3550 is currently sitting at. I abuse the heck out of my NV3550 and I have had no issues with it whatsoever. I do like the first gear being as low as it is, although for daily driving that low of a gear does make life a little annoying.
That said, I wouldn't consider one an upgrade over another - rather they are essentially equal. If you have an AX15 from factory, I'd just use it - same with the NV3550.
Maverickxeo is offline
post #12 of 22 Old 12-12-2019, 03:48 PM
BlueFl.Wrangler
Supporting Member
OK Boogie-- clue me in on what that is
post #13 of 22 Old 12-12-2019, 04:01 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
3 speed automatic. It's the stock auto transmission for 97-02 TJs.
TheBoogieman and hubbabubba like this.
Wheelin98TJ is offline
post #14 of 22 Old 12-12-2019, 07:57 PM
40vern
i love the ax15. i have done three swaps so far. one was a 97tj that i swapped in a ax15 and a 350. my 95 xj was 2wd auto, now it is a 4wd 5 speed. my 98 tj was a 4 cylinder now it is a 4.0 with an ax15.
you can get them new or pick one up for about 400 and run the heck out of them.
40vern is offline
post #15 of 22 Old 12-13-2019, 08:54 AM
jeep63
jeep63's Avatar
I second this. I've never personally driven a Jeep with an NV3550, but I have driven ones with the AX15, and my 10A has the NSG370 which is not an upgrade to say the least.
95 YJ-Sold
YJOTM 05/15,05/18
jeep63 is offline
