Best deal on a new 4.0L engine? - JeepForum.com
 5Likes
  • 1 Post By dirtdude723
  • 1 Post By ZEN357
  • 1 Post By joeyroe
  • 1 Post By TJnBC
post #1 of 9 Old 07-08-2019, 07:42 AM Thread Starter
dirtdude723
dirtdude723's Avatar
Where is the best place to source a crate engine?
My 2002 finally bit the dust at 249,000, cracked piston, rings in oil pan, cylinder scored; depending on the numbers it's likely cheaper to just replace than hone, sleeve and rebuild.
gsindela likes this.
dirtdude723 is offline
post #2 of 9 Old 07-08-2019, 08:03 AM
ZEN357
ZEN357 is offline
post #3 of 9 Old 07-08-2019, 08:58 AM
joeyroe
I got mine from these guys several months ago, and so far, not a single issue...
https://www.powertrainproducts.net/J...GINE-p/656.htm
joeyroe is offline
post #4 of 9 Old 07-08-2019, 09:36 AM
gsindela
Sorry to hear about your bad luck. Good luck with the project!
gsindela is offline
post #5 of 9 Old 07-08-2019, 10:41 AM Thread Starter
dirtdude723
Oh it's more,than done its job the last 17 years, can't complain a bit, knew it would happen eventually.
The plan is to replace/rebuild and keep on keeping on.
post #6 of 9 Old 07-10-2019, 04:06 PM
TJnBC
LS swap time
2006 LJR...the madness begins again
TJnBC is offline
post #7 of 9 Old 07-12-2019, 12:18 PM
Kaptainkid1
Kaptainkid1's Avatar
Have you consider a Diesel swap? I've seen people put in 1996-2004 VW 1.9 TDI used and get great low end torque 250lbs and 190whp. They also get 35 hwy mpg in a Jeep swap. If I we're hell bent on keeping my Jeep after a blown end and had the skill set up to swap a motor I would do a TDI in my Jeep. Great power and tons of used parts, and aftermarket support for the VW fans. It seems the TDI swap is done for a lot of builds besides Jeeps.
Sent from my SM-J737T1 using Tapatalk
Kaptainkid1 is offline
post #8 of 9 Old 07-12-2019, 12:52 PM
2jhanna
Not a new crate engine, but did you try daveysjeeps.com. Look on their website. They part out jeeps for a business and up the road from you in Ohio.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #9 of 9 Old 07-12-2019, 03:53 PM
Kaptainkid1
Here is a TDI swap.
Here are few company's too:
https://www.cotybuilt.com/
https://www.bruiserconversions.com/p...k-jku-wrangler
