BBK Throttle Body problem Solved. - JeepForum.com
post #1 of 2 Old 05-08-2018, 02:07 PM Thread Starter
trefts
It's a long post so here's goes.
I was having trouble with my idle over the last couple of months. It was slowly creeping up. When the engine was warmed up it would idle around 12-1400 rpm's at a stoplight. The check engine light (cel) would come one periodically as well. The OBD2 code said I had a bad O2 sensor (bank 2 sensor 1). I replaced the same sensor twice before going to mechanic for him to look at it. He found the exhaust manifold had some loose bolts so he tighten them up. This helped some. My idle went down to around 11-1300 rpm's now when the engine was warm. But now the idle was still high, the CEL was on, and now it sounded as if my engine was a tea kettle brewing tea. I replaced the idle air control valve with a MOPAR part and no change. I had a very high pitch whistle noise coming from my engine only when it was under load. I could park it in my driveway, pop the hood, and rev it but no noise would be heard. It was only while driving. and It was getting progressively louder and more pronounced. I took it back to the mechanic who performed a smoke test. He said the only smoke that was seen was coming from the throttle body. After doing a lengthy internet search and calling the local Jeep dealer. Mopar no longer makes a throttle body part, so I ordered an after market part. A BBK Throttle body. I installed the part. and things became worse. My idle was completely erratic, it would stall out, it would run very high (around 2200 rpm's) and occasionally idle normal, CEL was on all the time and whistle noise was still present. After doing all I could think of, I went back to the mechanic and he took a look. He couldn't find anything at first, but after we both compared parts we found the problem. The shaft on the after market BBK throttle body is longer than the MOPAR stock. If the TPS (throttle positioning sensor) is not attached properly it will result in a "stuck" or weak butterfly valve. Which in turn causes all the idle irregularities that I had. I attached pictures so people can see the difference. Also, the whistle sound was cured by using a part that wasn't cracked (like original throttle body) and making sure the gasket was sealed tight using a good gasket sealer. Now engine runs soooo much better, idle is consistent and CEL is off.
trefts is offline
post #2 of 2 Old 05-08-2018, 02:58 PM
jeff_in_rc
Glad you found the problem, those kinds of problems can be a bear.
2004 Jeep Wrangler Rubicon
Member of Off-R-Rockers California Chapter Facebook Group
jeff_in_rc is offline
