bad vibes after offroading/ could use advice on skid plate and SYE - JeepForum.com
post #1 of 3 Old 03-28-2007, 09:02 PM Thread Starter
thelazerviking
I have 32s a 2 inch lift and 1 inch transfer case drop. that's how i bought it.
There are a few questions in the following regarding skid plates, SYEs, and TC lifts
Today i bottomed out and smooshed up my TC skid plate. I'm getting bad vibes post-smoosh. I even even feel it shaking while idle and not moving but i think that's a different problem. While moving, is this possibly becasue it raised the TC and the pinion angle is off with the driveshaft? will getting a SYE and CV solve this (I'll also be building a new custom skid this week but will the SYE solve the vibes regardless? can i undo the 1" TC drop with a SYE to get more ground clearance post new skid plate? I don't really want to lift the jeep much more, just get ground clearance. i'm not too keen on the idea of a motor mount lift or a body lift over 1". I like haveing a good center of gravity. I drive it like a sports car in the curves and i'd liek to continue doing so. best ways to get ground clearance? any kind of other suggestions- I'm into it
have a good night,
thanks a lot
james
thelazerviking is offline
post #2 of 3 Old 03-28-2007, 09:06 PM
silvergreentj
silvergreentj's Avatar
possibly, check your tranny mount for compression...until i read about your smash, i was thinking you didnt clean the inside of your wheels and the mud/gunk was causing an imbalance.
good luck
Slow Life-02TJ-35 Trepadors
98TJ-33 Mtzs
Low Life-87 slammed e30
silvergreentj is offline
post #3 of 3 Old 03-28-2007, 10:20 PM Thread Starter
thelazerviking
if i do a 1" motor mount lift and a 1"body lift and a SYE and put the skid plate back at stock height will that be okay untill i cna build a new plate? it's smashed up probably 3/4 of an inch so it will basically be like it's raised 3/4" over stock. what kind of involvement is there doing a 1" MM and BL together? will it even work?
also, i need to find out the geometry of the skid before i build it, unfortunately i obviously can't exactly compare to mine
thanks
Skid plate advice lbsnowryder YJ Wrangler Technical Forum 0 07-02-2009 02:58 AM
Skid Row Evaporative Canister Skid Plate mrsig JK Wrangler Technical Forum 6 01-26-2009 08:46 AM
Anyone run a Muffler skid plate? A skid plate like the Kilby? JK Zombie Butt JK Wrangler Technical Forum 1 09-04-2007 03:51 PM
Skid plate trim job & vibes jkilday4 TJ Wrangler Technical Forum 5 03-28-2006 11:20 AM
What skid plates are essential for offroading? And HID headlights? diveguy TJ Wrangler Technical Forum 22 12-23-2004 08:40 AM
