back seat won't go back in... - JeepForum.com
post #1 of 5 Old 07-21-2003, 02:07 PM Thread Starter
mud4blud
mud4blud's Avatar
The back seat on my 97 won't' go back in correctly. the short bars that slide through the seat barcket seem to be too short to go in both sides. I know it fits, because it was in there originally.
Also, what are the pins that go in the notch of the bar (under the seat) called? size?
thanks, any help is always appreciated, Scott
mud4blud is offline
post #2 of 5 Old 07-21-2003, 02:17 PM
Dee Cue
Dee Cue's Avatar
I don't know about the '97's... But my '03 has a handle which you need to lift once you are inserting the seat back into place. Easiest way for me is to slide it in horizontally, not vertically and it should catch quite easily. Hope it works for you.
Blk, '05 LJ, 6-spd, 3" Zone SL, 33" BFG AT on Soft 8's
Dee Cue is offline
post #3 of 5 Old 07-21-2003, 02:21 PM
Jim Shanks
Jim Shanks's Avatar
You do know the "pins" go on the inside of the rear seat brackets right? If you are trying to shove the post all the way thru the bracket and then isntall the pin on the outside, I could see how it wouldn't reach the other side. Not sure what the technical term is for the pins. Just tryin to help.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #4 of 5 Old 07-21-2003, 02:38 PM
KaiserJeep
I used to have a '97 SE with a rear seat and an Instatrunk. You can't see the spring-loaded clips that hold the seat in place if you have the trunk - but you have to reach down those two wells to release the clips before the back of the seat latches in place. If you don't have the Instatrunk, you should be able to see what I'm talking about.
The 2003's are much better - the handle in the center of the backseat operates the clips - no more fumbling with something you can't see and can't quite remember.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline
post #5 of 5 Old 07-21-2003, 03:19 PM Thread Starter
mud4blud
mud4blud's Avatar
don't have the trunk, but thanks for the help guys. i've got it figgerd out now. I just have to go to the hardare store to get some new pins...........lost them both
thanks again, scott
mud4blud is offline
Unlimited - Adjusting Rear Seat Back Support (the vertical part of the back seat) 03LX470 JK Wrangler Technical Forum 8 06-05-2014 11:31 PM
Any trick for getting RR neoprene seat covers to conform to seat back? FrankGG TJ Wrangler Technical Forum 2 06-05-2009 08:12 AM
high back or low back seat covers mufan TJ Wrangler Technical Forum 0 07-04-2008 10:20 AM
Moving the back seat back 6"or so MuddySport TJ Wrangler Technical Forum 2 02-01-2004 10:00 AM
Adding 3point seat belt to back seat NJjeepster YJ Wrangler Technical Forum 8 10-23-2002 09:03 AM
